87 4runner turbo swap
So I recently bought a 1987 4runner that was just a base model. It's not bad but I'm considering swapping in the turbo motor from the same year. I know they only came with an auto trans so I'm wondering I'm my 5 speed manual will hold up to the added power... Any sort of input would be helpful
And if you happen to have a turbo engine and your located near my area let me know
Originally Posted by Rolladude1166
(Post 51620625)
keep reading...R151F is a 5 speed that came on turbo trucks they also had a 23 spline shaft on the TC vs 21 spline on the other trucks, rear turbo differential also had 4 pinions like a v-6 third. |
Originally Posted by ocdropzone
(Post 51620631)
gee and what location would that be since you don't say?:bounce:
California's pretty big...you may want to be more specific as to where you are :)
For starters, you can update your sig or avatar to indicate where the Sam Hill you are. |
they came in 5speed to, the 4runner model only came in auto but the pickup had the 5speed tranny, the turbo 5speed tranny is different then the regular 5speed tranny they both work tho but the turbo one is stronger.
the turbo tranny has 23 spline to the 23spline transfer case. (r151) the normal 5 speed tranny has 21spline |
what about the diff? should i change that or will the stock one be ok? and does anyone know where i can get those cool ass digital gauges from?
Be cheaper and much less hassle to just buy a 22RET model already.
:wabbit2: |
ive looked and couldnt find one. if you guys have a motor to sell me thatd be great!
Originally Posted by waskillywabbit
(Post 51621180)
:wabbit2: probably be just as expensive doing a 3.4 swap. Probably easier too. lol. I haven't done it so that would be just my opinion. Cost per HP is definitely better with the 3.4 swap I would imagine too. |
