Your google pics were a no go..
That case was used for 15 years |
You cannot view the photos?, im having trouble attaching them in another way. Are there threads on replacing this seal? I've looked everywhere, only to find output shaft seal replacement threads on an 01 runner. Its simular, but the seal doesn't sit inside the companion flange like mine does, it pops right out, without removing the dirt shield. this is that thread, hopefully it will narrow down what I'm talking about: http://www.toyota-4runner.org/3rd-ge...ow-diyers.html
Figured out the problem. take a large socket and punch it out the inner metal over a vice. The new replacement gaskets do not actually sit the same as the factory ones. They sit on the inside of the outter metal piece that faces the drive shaft, when the factory ones sit in the middle of the two metal pieces you punch out. Therefore the inside metal piece is no longer needed because the new gasket is actually the same shape and form of that metal making a better seal. No more leaks. Hopefully this answers anyone's questions with the same problem.
