YotaTech Forums
-   Newbie Tech Section (https://www.yotatech.com/forums/f120/)
-   -   22re issues (https://www.yotatech.com/forums/f120/22re-issues-299144/)
satans4runner Feb 26, 2017 12:22 PM
22re issues
Hello friends! So today I rolled onto the freeway with my 85 toyota pickup and the engine cut out. I tried restarting and she's trying to turn over but ain't starting. I checked the fuses and recently changed the fuel pump/filter everything is sat. Upon doing research I saw checking the distributor cap, and maybe a electrical problem some where else/or mechanically like the timing chain etc. Prior to ripping the engine apart and swapping the timing chain, water pump, etc... any tips on some electrical areas to check....maybe common spots or something that I can check and make sure it is getting power. Engine has 223,000 miles so might be that time for a rebuild a as well. Any help is greatly appreciated!
-roman
L5wolvesf Feb 26, 2017 01:51 PM
I suggest checking the basics first - are you getting spark and fuel?
Co_94_PU Feb 27, 2017 09:54 AM
First off get a Manual, Chilton, Haynes or Toyota
All the manuals should/will have trouble shooting flow charts. Start there. It will save you time, money, and familiarize you with the engine and its systems.
