Truck won't start
I had to pop-start it to get it home last night. It doesn't even crank over, when I 'hit' the key all it does is click. Sounds like the starter is clicking. Starter toast?
BTW I have a '94 pickup with the 22re and a 5spd. |
sounds like a starter or solenoid.
Ya, sounds like the starter to me, but you might want to clean your battery connections as well. Bad connections will also cause this to happend.
Here is a simple voltage check you can do to help isolate the cause of the no-start problem:
http://www.4crawler.com/4x4/CheapTri...shtml#EasyTest |
This happened to me this morning. Went to start it, and would not turn over. Can hear the fuel pump kick in, and the starter would click, but would not turn.
And its not the battery. So let me know what you find out on yours. |
I seemed to over look the clearly obvious:bang: :bang: the battery cables were almost falling off. man I feel dumb:bang:
