YotaTech Forums
-   86-95 Trucks & 4Runners (https://www.yotatech.com/forums/f116/)
-   -   trimming upper control arm (https://www.yotatech.com/forums/f116/trimming-upper-control-arm-205570/)
irvingdizzle Feb 26, 2010 09:48 PM
This part of the arm is barely rubbing against the tire. Has anyone taken their grinder and removed the part that is circled with success?
http://i48.tinypic.com/2ldggnp.jpg
peow130 Feb 26, 2010 10:12 PM
...so you'd rather weaken a VERY important piece of your vehicle, instead of just buying a spacer?
OutlawMike Feb 26, 2010 10:17 PM
Yes, I ground that lip back a bit on my rig. Not an issue to grind it, that material out at the end is not in the critical loading area for the control arm.
Grind away, and wear safety glasses.
peow130 Feb 26, 2010 10:21 PM
i wouldnt grind on a critical piece of my vehicles suspension, especially at the end where the balljoint rests :/
ldivinag Feb 26, 2010 10:28 PM
some people who run the BJ spacer actually have to trim that area to fit the thing in.
on a side note, maybe the OP's wheels have the wrong backspacing?
desertcamper67 Feb 26, 2010 11:39 PM
You only have rubbing on one side?
If so maybe your spindle/knuckle is bent
milehigheric Feb 27, 2010 01:00 AM
The lip on the end is actually structural...The torsion of the 90 degree lip helps to stop the whole thing twisting under load. You can modify it if you want, people pie cut UCA's, you just have to put the strength back in when your done.
paynemw Feb 27, 2010 01:57 AM
Sonoran Steel has shaved upper A-arms... they take stock 3rd gen runner a-arms and cut them and then weld it up... check it out on their website for a reference
yoterr Feb 27, 2010 06:46 AM
just buy some 3/8's spacers or something, you can buy em at the autoparts store much easier
xfactor203 Feb 27, 2010 07:23 AM
This thread has pictures of an upper control arm cut and welded to clear tires:
https://www.yotatech.com/forums/f116/morph-187544/
