Tail light upgrades
What options do we have for tail light upgrades as far as LED etc? Links appreciated
I bought these, you need to change flasher to avoid the LED fast flash when you install most LED directionals:
1157 2 Tail/brake lite bulbs: https://smile.amazon.com/gp/product/B076YT323X/ref=ppx_yo_dt_b_asin_title_o00__o00_s01?ie=UTF8&ps c=1 1156 6 directionals/backup: https://smile.amazon.com/gp/product/B0721FNCWP/ref=ppx_yo_dt_b_asin_title_o00__o00_s01?ie=UTF8&ps c=1 Flasher: https://smile.amazon.com/gp/product/B00JXLHE8S/ref=oh_aui_search_asin_title?ie=UTF8&psc=1 I got 4 LED T10 bulbs for the license plate and parking light bulbs on eBay |
For the flasher unit, I have used a Tridon EP-35 unit,it was a direct replacement for my 94
not sure how far you want to go but I cut out the back of the light housings on my 4runner brake lights:
Originally Posted by dropzone
(Post 52415522)
Did a few miscellaneous projects today before I tore into the transfer case
After a few years of using zip ties to mount the license plate and front turn signals figured it was about time to do something a little more refined Center mounted the license plate with some counter sunk bolts welded on the winch mount https://cimg3.ibsrv.net/gimg/www.yot...31eab3f394.jpg hard mounted the turn signals https://cimg4.ibsrv.net/gimg/www.yot...924cf45c42.jpg https://cimg0.ibsrv.net/gimg/www.yot...79582038c4.jpg https://cimg2.ibsrv.net/gimg/www.yot...af8d2242bd.jpg when I made version 1.0 of my LED taillights I got a little crazy with clear epoxy and it ended up obstructing some of the LED's. version 2.0 came out a little better. New one on the left, old on the right https://cimg8.ibsrv.net/gimg/www.yot...b80fc78d61.jpg Old https://cimg6.ibsrv.net/gimg/www.yot...4f6d6cbfb5.jpg new https://cimg2.ibsrv.net/gimg/www.yot...8f10c62e2c.jpg Occupation of the garage has begun https://cimg6.ibsrv.net/gimg/www.yot...9a784c108f.jpg
(Post 52415593)
Was feeling like crap all day so all I got done was as swapping the stock turn signal flasher for an EP-35. It is LED compatible.
the flasher is sort of a pain to get to. It is mounted under the dash to the left of the steering column. pulling the HVAC tube out of the way helps get you a little more room https://cimg3.ibsrv.net/gimg/www.yot...711e7ba14a.jpg Places will tell you the EP-35 isn't compatible but it was a direct replacement https://cimg3.ibsrv.net/gimg/www.yot...c9018a2968.jpg Eliminated the hyper flash https://www.instagram.com/p/BscJQEEBJBF/?utm_source=ig_share_sheet&igshid=t9qj685p8q5r https://cimg2.ibsrv.net/gimg/www.yot...8a989427ac.jpg Amazon has a complete replacement LED housing |
Yeah, the flasher I used was not a direct plug-in for a 92
| All times are GMT -8. The time now is 05:38 AM. |
