YotaTech Forums
-   86-95 Trucks & 4Runners (https://www.yotatech.com/forums/f116/)
-   -   Rear window interchangeability? (https://www.yotatech.com/forums/f116/rear-window-interchangeability-250954/)
silvr6 Mar 16, 2012 07:10 PM
I have a 1990 regular cab with a solid rear window. I came across a complete rear slider out of an extended cab 1992. Are the two rear windows compatable.
Can I swap in the extended cab rear window to my regular cab pickup?
justin_4runner Mar 16, 2012 08:39 PM
i want to say yes u can, its just a rubber seal that holds it in,
old fart Mar 18, 2012 12:06 PM
Yep, it will, bout the only differences is heated, or non-heated, w/o solar energy reflecting; bronze tint, exc. privacy etc. some had the solar reflecting, some dont, most had bronze tinting, some had the dark tinted glass.
BMcEL Mar 18, 2012 01:29 PM
NO. The xtra cab back glass is larger and WILL NOT FIT.
Holy bad info you guys.
silvr6 Mar 18, 2012 01:29 PM
Got the old window out and the new slider is an inch taller. The slider is a factory Toyota piece. What is the deal?
BMcEL Mar 19, 2012 08:37 AM
:facepalm:
old fart Mar 20, 2012 04:00 PM
Crud we just pulled one from the yard less than a month ago, 91 reg cab, 92 ex cab, it fit fine on the install in the 91 reg cab, if it was a shaved down slider, none of us could tell? Even the hollander interchange said it fit. I wonder what's the deal with the one we pulled/installed now.
BMcEL Mar 20, 2012 04:28 PM
If it fit in the reg cab, it wasn't from an xtra cab.
glowz825 Jun 19, 2014 02:58 PM
Sorry to bump an old thread but.......I have a 93 extended cab 4x4 that has a busted rear slider. I bought a used one of which the seller said it came from a 90 Toy ext cab. I removed my old window only to find that the used window I bought it approx 1 inch taller than the one I removed. To be sure about the difference I removed the slider glass from the new window and compared it to the remaining slider from my old window and it is 1 inch taller.
Both have Toyota Glass so I would assume they are factory sliding windows. Is this 1 inch difference (or 1/2 inch if centered) enough of a differece to keep me from installing this? I tried for 3 hours using various methods to install it and it seems just a bit too big to get the seal to seat on the inside. Any insight would be appreciated.
MudHippy Jun 19, 2014 03:39 PM
The differences are 84-88 vs. 89-95 and regular cab vs. Xtra cab. 84-88 is slightly smaller than 89-95. Regular cab is slightly smaller than Xtra cab, all years.
79-83 is slightly smaller than all of those, and(of course) doesn't include an Xtra cab size.
glowz825 Jul 8, 2014 04:56 PM
So why is the rear window that is currently installed shorter than the one I bought from a 90 4x4? The window from the 90 will not fit, not even close, while the current one reinstalled with not too much effort. Is the rear window from a 89-95 regular cab larger than the ext cab? Does it matter if it came from a 2wd or 4wd? Sr5 or DLX?
