Power Steering Pump Rebuild Question....
When yall replaced all the seals in yalls powersteering pump during a rebuild did the kit contain an e clip and 2 rubber gaskets not used? Are these parts used on the 22re PS pump but not the 3vze?
Reason being I took my PS pump COMPLETELY apart and replaced EVERYTHING I could. Even the TFSM only has one replacing 5 or 6 pieces. |
Well? Is the rebuild kit meant for both the 22re and the 3vze hence the extra new parts I couldnt find?
Do you show the rebuild kit as prt #A30-07-G8 ;04446-20031 ?
I did mine recently (3.0) and I'm pretty sure I used all the parts, but I can't tell you for sure. Someone has to have done it recently and can confirm...... |
I think I used all the parts in my kit. There are a lot of different kits and I had 3 different part numbers for it from 3 different dealers. I finally got a couple of different dealers to agree on one part# so that's the one I ordered. They should use your VIN# to order the correct kit.
Take a look here to see if you missed anything.
I got everything except for the "hidden" seal on the backside inside surface of one of the plates. But i still have an e clip and NO idea where it goes! LOL
Yeah that one is pretty hard to see.
Hello im just wondering if it is werth rebulding my powerstering pump or to just get a new one if so were can i get a rebuild kit
Well I guess it depends on how much time you have. It was defininely worth it to me. The kits are a dealer special order thing.
Clicky here for a write-up: http://members.cox.net/stacewilliams/ps-pump.htm . . . |
Great write up! Looks like I will be doing this SOON!
you can also get the kit from napa
Oh boy, spare parts when you get done with the rebuild.......hmmm, probably shouldn't have left overs.....
I'm getting ready to do this myself.... |
Back to life.
I also have those spare parts. I found where the lager o ring goes. I can not figure out where the smaller o ring and pinch ring goes. Does one go around the flow control valve. Maybe I was given the wrong parts. My kit did not come with the small copper fitting at the air control valve either. Any help is great! |
Originally Posted by Bumpin' Yota
(Post 50388035)
Not sure about everyone else, but my kit came with a drawing showing that the larger o rings are same size but different material and indicated where each one goes. 2 orings were in a bag within the bag and one o ring in another bag. The one on back plate is different material but same size as the vane o rings on each end of it. I tried a NAPA kit and it still leaked, got the Toy kit and now it's dry as a bone a month later. My kit was 04446-20031 |
Originally Posted by MisterB
(Post 50529487)
Back to life.
I was looking in the manual and there seems to be a few different pumps. I found the clips location on the other pump. They gave me that parts for that pump I guess. Here are my leftovers.
http://i56.photobucket.com/albums/g1...w/IMG_1522.jpg For the newb please define RTV thanks... |
RTV= Room Temparature Vulcanizing. RTV silicone or gasket maker means it cures at room temperature, etc.
i had those parts left over in mine from advance auto
i just rebuilt mine today 91 v 6 i had that spring clip left over too !! i is not on my pump i took every part out except for the bushing there is a few oring in there that are pretty hard to see you should use every o ring..
