Pizza Cutter Options
I trying to improve my gas mileage on my DD and am thinking of running 33x10.5 or 33x9.5R15's. Does anyone know of other AT tires other than BFG's? I tried Pirate and all they suggested was Swampers...
I do like ProComp AT's, had good lucky in the past with 30.5x9.5 on my 2WD Ext Cab, but they don't make either size... Thanks for not flaming me too bad! |
Well in the size range I know you aren't really looking at Swampers but did anyone suggest the TSL radial 32x10.5? It would still be a radial tire so it would do better on the street and also probably be a little better on gas than a bias ply.
Also I believe Dunlop makes an A/T and M/T in the 33x10.5 size. |
If you wanna increase your MPG, you get smaller tires....to a certain degree.
I ran 33x9.5x15 BFG AT bought them brand new for $134.99 each from discount last month
http://i82.photobucket.com/albums/j2...01-08_1245.jpg http://i82.photobucket.com/albums/j2...01-08_1243.jpg http://i82.photobucket.com/albums/j2...01-08_1242.jpg http://i82.photobucket.com/albums/j2...25-08_1756.jpg |
run some 31's if you want better milage and swap on some bigger ones for wheeling
The Pampered Chef offers nice ones, or just go to Wal-Mart. Your options are endless to cut a piece of this splendid food item.
(BFG) |
Pampered Chef sounds good, nice stuff. Or I could whip out a Benchmade...
I did this spread sheet, looking at diameters and weights, trying to do a simple comparison. I did notice a big difference between stock and the 32 MT's on it now, they're almost 10 lbs heavier (per specs - not actual weights). 33x9.5 are about 5 lbs less than the 32's and a narrower contact patch. But then maybe 31x10.5 will have to do... And I wouldn't feel so oblugated to regear from 4.10's... What kind of mileage are you getting with 31's? I get 13-14 combined right now with 32x11.50 ProComp MT's... |
Love those pizza cutters, I wish I needed tires and had the money to regear.
i am running 265x75 Toyo OC M/T and i gained MPG from my 31x10.5 Pro Comp Xterrain. so skinny tires may not make a difference. i only gained MPG because the Toyo's hold more PSI. at 43PSI i have 25MPG highway on average, sometimes more.
ran 235/85/16 revos on my 97 for a couple years, true measurement on them is 32.1 x 9.3 but they are load range E, so not the comfiest ride. got really good mpg with them though, especially if i bumped the pressure up some.
Check these out!!
https://www.yotatech.com/forums/f116...utters-135576/ https://www.yotatech.com/forums/f116...rs-snow-98388/ mmmmm pizza Rob |
