loctite during engine assembly
Should I use removable strength loctite on every bolt when I assemble my engine? Or are there just certain bolt that need it?
good one
You know that is a good question, I put thread sealer on any bolts that are getting corroded. If they were clean when they came out then they go back in the same way.
I am very recently in the habit of retorqing all engine bolts after initial 200 mile breakin following dissasembly as I found some have slackened up in the past so maybe locktite on the last 2 or 3 threads wouldn't be a bad idea. who the hell knows, was probably me not tightening more bolts :) minimizing distractions in the workplace can benefit more than anything else :) very recent good advice I have formulated :great: Pete |
