lock front or rear ????
Ok so im having a little trouble deciding to lock either the front or rear with a lunch box locker as i see they are called.. Any pros and cons that anyone has run across, what brand is the most friendly, and wheres the best place to get said locker for the money??? trying to get this done before i pull out the rear and add the 5.29s front is already done but no locker yet.Any advice from people running them is what i need.Will be going on a 90 4runner that is a dd and weekend warrior
thanks guys and girls |
Rear Rear Rear Rear Rear
What vehicle, what do you use it for?
If you plan to only have one locker, run it in the rear. |
Rear, a front locker means you want a dedicated trail rig as its not quite that easy to drive on the road anymore with a front locker.
Rear and maybe search there is lots of info on this.
i don't have any lockers, but everything i've read thus far on the subject says to lock the rear first. personally, i'm doing an SAS and adapting e-lockers to both axles. i like versatility. ;)
-shaeff |
Originally Posted by CJM
(Post 50421358)
Sorry to jack but how streetable is a front truetrac?
(Post 50421358)
Originally Posted by 89-4Runner
(Post 50421544)
couldn't you still drive it on the street with the hubs unlocked?
I disagree. The FRONT locker makes more difference offroad than the rear. BY FAR. It also has more downsides, a lot of which are mitigated by manual hubs.
BOTH! Theres the right answer. Well really the right answer is rear then manual hubs then both. I can't wait to be locked front and back and our wheel all the tough guys on 40's :D
< Gotta love those manual hubs :)
Originally Posted by jusfloorit
(Post 50421756)
Ok fellas just for the record i do have manuel hubs and getting ready to run 35s with 5.29 stock 3.0 205000 have front pumpkin out so its a very interesting delima so as long as i dont lock on pavement the front will be ok?? but the best is to go both???
Then no worries expect pushing those massive meats around.
The "best" combo depends on what you intend to use your rig for. There is no single right answer.
For hard-core off-roading, you generally want full lock on both front and rear. Having a selectable locker like an ARB in the front can help with the steering issues. For moderate off-roading, go with a detroit locker in the rear and a truetrak up front. No issues with turning radius with this setup and the truetrak is much kinder on the front linkages and drive shafts than a full locker. But take note: the truetrak will unlock if you pick a front wheel up off the ground which is very common with IFS. You can cause the truetrak to lock again by applying light brakes in this situation. This is no real problem with an automatic tranny, but it can be a bit of a challenge with a manual tranny if you're trying to work the clutch and throttle at the same time. Something to consider when choosing a truetrak. If money is an issue, lock the rear first. Avoid the lunchbox lockers if possible and go with the detroit locker or similar. They are much stronger. |
My front is locked, my rear is on LSD.
I drive my truck on pavement with the hubs locked in all the time. I think the front locked will get you farther, but its been my experience that isn't always a good thing. I've gotten farther, then gotten really stuck, since the rear couldn't back up what the front was talkin. I'm going to go with the "it depends" answer, and let the rest of you figure it out. |
i think lock the rear. i personally wouldnt put an auto locker on the front if its ifs with 35s
to lock or not
well Iv got a 86 wtih lockers in front, and rear yes manual locking hubs, and yes every time i get gas or food someone reminds me that my truck is making a ratchet sound and if you turn hard you will hear a slam noise( nothing broke but it took about three times before i learned how to turn), and yes you have the ability to just get stuck in a harder way, soo get em and have fun, and extra long un-stuckem roap:hillbill:
| All times are GMT -8. The time now is 05:10 AM. |
