Light bulb for a/c indicator button?
Hey all, trying to source the a/c indicator light bulb for the 84-88/89 trucks/4runner but cant seem to find it. Does anyone know the part number and/or place I can order one from?
Is it the same switch as the '91? I had the same issue. The switch worked but no light. Replaced it with this:
It was a little tighter fit but it worked for me. |
No, its just a little button that you put out and there is a very small bulb but cant seem to find it anywhere, let along find a picture to show it
The Toyota parts diagrams ( that I have found anyway) do not show the bulb itself for the A/C button, just the whole switch assembly.
Chances are good that Toyota used the same bulb in other switches or applications, but I have no idea which ones. :safari: |
For my '92, the LED replacement bulbs (edit: for illumination only) that fit in my switches are size T3 and looked like this:
https://cimg6.ibsrv.net/gimg/www.yot...81971202ff.jpg I am sure you can also find regular T3 bulbs if you don't want LED, I found the LEDs on eBay. |
Paul22RE: Those bulbs are to illuminate the switch when you turn on the headlights. (On my '94, I have a T1 size bulb, but it looks like your bases will fit and so the bulb size doesn't matter.)
if I8URSVT is asking about the indicator bulb, so far as I can tell it's a built-in LED and can't be replaced separately. |
Wow, i was just about to post/search this same question about the indicator bulb.
second, how do you remove the switch, or panel? If i can get to the led, i’ll try to fix it. |
The switch just pops out in my 92 without removal of anything, but maybe because the tab for the electrical connector in the back is missing? I double-checked, Scope103 is correct: the T3 bulb is just for illumination of the switch, the tiny green "on" light is internal and does not appear to be replaceable. Best to just find a used switch on eBay.
https://cimg2.ibsrv.net/gimg/www.yot...cb3c8d90f.jpeg
the light im referring to is green button in photo. I believe it is specific to 84-88(89) pickups and 4runners. You have to pull the front of the dash off to access it (At least I did). Hoping someone has a part number or source to get the bulb. I pulled the bulb out before, so i know it can be replaced by itself. |
Well, one COULD try the dealer.
84999-10110 https://parts.lakelandtoyota.com/p/_...499910110.html https://parts.lakelandtoyota.com/p/_...193089111.html I'm not familiar with your vintage truck, so I don't know if there is an illumination bulb distinct from the indicator bulb. |
| All times are GMT -8. The time now is 12:30 AM. |
