Is this the knock sensor harness?
I had to replace the power steering pump hose and when I did I knocked this wire out of the connector. After doing a little research I thought it was the knock sensor harness. I ordered one and it doesn’t fit (all the reviews say direct fit) and it’s really short. I’m not sure what those wires go to now. Does anyone know what this is? I do know my engine has started running like crap ever since I broke it. |
Originally Posted by cabledawgrunner
(Post 52410877)
... I knocked this wire out of the connector. ... Does anyone know what this is? ...
Yeah I did. I can’t do it on my phone for some reason. Is there an app that works with yotatech? And I found out my dumbass was looking at the egr hahaha you live and learn. |
Then you should have code 71. That will dramatically retard the ignition timing to save the engine. "run like crap."
Originally Posted by scope103
(Post 52410894)
Is is there a different way of resetting the ecu once the connection is re-established or am I going about this the wrong way? Thank you again for all of your help |
| All times are GMT -8. The time now is 12:16 AM. |
