Just saying HI and a few questions.
First off I want to say HI to everyone!
Second I'm new to this forum but not new to forums or Toyota's, as I have had a 94 pick up for about 7 years and I love it, it has never let me down. I just got a 4Runner for my girl to teach her to drive and give her a good 4x4 for snow and bad weather. I got a very good deal on it, it's a 4Runner sr5 3.0 v6 and I started by giving it a full tune up. I have also done the following so far: New rotors because of a pad that failed and the rotor was down to the cooling fins on one side rebuilt the front calipers replaced all 4 CV boots new transmission filter new differential and transfer case oil fuel filter oil filter plugs wires cap rotor drained and replaced brake fluid power steering fluid So, other then just saying hi, I would like to know what are some of the other things I need to do, and are there any problematic areas on the 4runner? Thanks in advance for all the help, Blue |
i dont know much about the 4runners...but welcome to the site. GREAT info all over
I would also replace your coolant. You should have seen my head on my pickup when I bought it. It had electrolysis all over just breaking it down which led to a head gasket issue.
Hey, welcome, nice to see people who take good care of the rigs they own. I would second flushing the coolant, coolant carries a voltage and when it gets too old the voltage can increase making it eat away at the valvetrain. Also i would flush the power steering and refill it :bigok:
Hello there...welcome.
Hmmm...I'd check with a dealership on the VIN and see if the headgasket was replaced under the recall. Then, a compression test just to see where things are at. That's really the only "problematic" area specific to the 3vze/3.0. But, if you've changed all the fluids and brake stuff and it's running good.....leave it alone and drive it. If something turns up, take care of it then. Oh...I would run some injector cleaner through it and inspect and grease the driveline. |
Electrolysis...
One failure mode associated with dirty coolant is known as electrolysis. Electrolysis occurs when stray electrical current routes itself through the engine coolant. The electricity is attempting to find the shortest path, and impurities in the coolant often generate a path of least resistance that the electricity travels across. The source of this stray electricity is often from electrical engine accessories which have not been properly grounded. A missing engine or transmission ground strap can also cause the coolant to become electrified. Sometimes the path of least resistance becomes a radiator, a heater hose, or even the heater core. These components are often well grounded, and offer a ground path from the engine to the chassis by means of the semi-conductive path of the coolant. |
welcome to the club. there a good learner car i just got my lerners and going for a drive to night. just make sure you tell her not to be a girl racer and speed arround the corners very bad things will happen
Originally Posted by Tylercs
(Post 50655345)
Originally Posted by apalmer1
(Post 50655377)
Originally Posted by 88-surf
(Post 50655404)
Originally Posted by bluemunkey1820
(Post 50655431)
we have a turbo2 rx7 for that
ok so almost done just waiting on the caliper rebid kit to arrive
so here are some pix http://i91.photobucket.com/albums/k3...k/DSC01861.jpg http://i91.photobucket.com/albums/k3...k/DSC01860.jpg this is the gunk i was taking about http://i91.photobucket.com/albums/k3...k/DSC01857.jpg calipers waiting on kit http://i91.photobucket.com/albums/k3...k/DSC01862.jpg a alarm that was installed will have to remove as I did not get remotes and they used vampire clips http://i91.photobucket.com/albums/k3...k/DSC01859.jpg bad pic sorry |
you guys are all confused over electrolosys.
it happens with 2 different metals in an electrolyte. they have to be electrically connected to each other in order for it to happen. the aluminum gives up electrons, and will eventually just fall apart. when you're talking about stray current going through the coolant thats known as stray current corrosion. they're two different things. |
Originally Posted by MMA_Alex
(Post 50657154)
it happens with 2 different metals in an electrolyte. they have to be electrically connected to each other in order for it to happen. the aluminum gives up electrons, and will eventually just fall apart. when you're talking about stray current going through the coolant thats known as stray current corrosion. they're two different things. http://www.drivewerks.com/Newsletter/vol-7.htm |
Nice, enjoy it!
Oh, and welcome!!! |
update
Now for a big one, I have also replaced the timing belt, both idlers, the water pump, and the thermostat. I fixed the electric windows because one did not go up and down (did a nice write up for it and pm'ed it to Cory so he will get it up in the tech section soon). I also got the radiator repaired, lots of new vac lines and only managed to mix up two of them, too bad it was a fuel return line and a vac line so after I got it un-flooded it ran fine, LOL. Now all I have left to do is bleed the brakes and get it registered, no smog though because my mom lives in a no smog county.
Man you've been going to town on that Runner. Sounds great. Welcome to the Forum.
nice clean 4Runner! i've got the same gunk on my Rad. but it has had n effect on anything, its just on the surface and not spreading
preventive maintenance....looks like you've covered everything. might want to check/change the diff fluids if there's a chance they've been submerged.
sounds like it's going to last a long time as long as you watch the temp gauge. |
Originally Posted by 87TurboYota
(Post 50681706)
Originally Posted by Belize Off Road Team
(Post 50681712)
Originally Posted by NaeSLaS
(Post 50681720)
