ignition
Car does not start. Key turns, but it seems like the spring broke. How do I replace that?
From what you describe it sounds like the electrical part of the ignition switch broke .
Depending what year pull the covers off to access the switch. Remove the lock cylinder (key turned to accessory push the pin and pull the cylinder out. there should be a screw holding the electrical switch in. Figure out if that is the problem This is off the Top of my head I may have missed a step!! |
I pulled out the lock cylinder and the ignition switch and found that the rod inside the bracket had broken. I couldn't find an after market part, had to order a new bracket from the dealer. I'll pick it up tomorrow and let you know if it works.
Take pictures, please.
| All times are GMT -8. The time now is 05:24 AM. |
