Originally Posted by Clifford1990
(Post 52371550)
Cold Start Injector Time Switch....is that a different name for Thermo Time Switch?
When looking around I get the above name more often. Such as this https://cimg1.ibsrv.net/gimg/www.yot...c2f0a6705b.png With the black one looking very similar to the one I'm looking for |
Very vague question...
Does anyone know where this goes? https://cimg9.ibsrv.net/gimg/www.yot...f687d4392c.jpg https://cimg6.ibsrv.net/gimg/www.yot...3d138104d6.jpg Also, can someone double check the following codes displayed in this video https://www.youtube.com/watch?v=TUg0...ature=youtu.be I have the following codes: 24, 31, 42, 51, and 52 Is this correct? |
That looks like the distributor hold-down bolt. That thick washer prevents the distributor from rotating which would change your timing. When you put that bolt in, be sure to use rtv or threadlocker to prevent an oil leak. It's one of 3 bolts on a 22re that require sealant.
I have an earlier ecu than you so I'm not familiar with those codes, but yeah the numbers look right to me.
I took a look at what the codes meant out of curiosity and you either have a handful of bad sensors, or much more likely some faulty wiring. Check each sensor with a multimeter to see if it's getting power. If not, you'll have to trace a wiring diagram, physically locate the wires-in-question and visually check for corrosion, breaks or damaged insulation. Also likely is that the damage all occurred at the same place. What a pain, glad I have an '85!
I do agree with you on the sensor wiring.
I am familiar with that bolt on the distributor. Could you tell me the other two locations you mentioned? |
(Post 52373513)
Originally Posted by Minerbob
(Post 52268665)
CSOUT said: Bump for this thread to let you guys know you helped out another yotatech member. Just received and installed the two seals:
90304-76005(MAIN) CV SIDE 90316-60004(SUB) KNUCKLE SIDE Fit perfect on my '90 SR5. And this says it all... The KOYO-CR PN is off the seal I pulled from the knuckle. https://cimg6.ibsrv.net/gimg/www.yot...382d63e5b.jpeg https://cimg9.ibsrv.net/gimg/www.yot...f6389d602.jpeg |
Reply about dust seal.
On the older vehicles those dust seals were not vehicle specific however I believe it may actually be called a axle seal!
QUOTE=Brapp2Smokin;52473764]Hi all, I know this is an old thread with lots of great info but I spend 40 minutes at Napa looking for this knuckle seal using all the PN numbers on here with no luck. I have a 91 4x4 pickup. Does anyone have a link to the knuckle dust seal part instead of a PN? My old rubber seal that came out of the knuckle fits perfectly over my new CV axle, so I don’t think I need anything specially but I can’t find that standard dust seal for the life of me. The KOYO-CR PN is off the seal I pulled from the knuckle. https://cimg6.ibsrv.net/gimg/www.yot...382d63e5b.jpeg https://cimg9.ibsrv.net/gimg/www.yot...f6389d602.jpeg[/QUOTE]IQUOT |
I realized what I was doing wrong and wow is it embarrassing. Hopefully, you guys at least get a good laugh. I tried putting the seal in with the old metal lip still in the knuckle. Enjoy that for what its worth!
Dust seal
The replacement seals can be difficult to install however I had a 55 willy jeep with the same problem and was told to put the blue high temp grease in the knuckle. Took a while to get it in there with a spoon but that was 25 years ago and haven't had any problems. I was told the the high temp grease stayed thick enough to not run out from around the seal but would thin out enough to keep things lubed. If you do this I recommend you fill it up with as much as you can possibly get in it.
