How is the 2nd gen auto antenna supposed to work?
On mine, if I start the vehicle with the radio off, the antenna stays down.
If i then turn on the radio, the antenna goes up. If i start the vehicle with radio on, it goes up. If i turn off the radio, it stays up. I thought it was sposed to go down when you turn off the radio. Mine won't go down until i turn off the ignition. ??? |
If it is an aftermarket radio/cd player than it controls the antenna. Therefore I would no worry about it unless it is a stock radio. And in that case I would probably think there is a short of some sort.
It's the stock radio.
So it IS supposed to go down each time you turn the radio off? Is is supposed to also go down when you insert a cassette tape while the radio is on? Thx. (Cassette tape! :D I think I still have some of those somewhere.) |
the antenna should go up with the radio on, and down with the radio off.
if you put in a tape when listening to the radio, the antenna should stay up, if you turn the car on while listening to the tape, the antenna should stay down. basically the radio is not wired to send the antenna up when playing a tape, but if the antenna is already up (like you were listening to the radio), it will stay up. at least thats what i've found in all my toyotas and 15 years of putting radios in them. |
what is a cassette tape?
Originally Posted by 80W90
(Post 50492260)
8 tracks no way !! there how big?
Originally Posted by da_bigg_wigg
(Post 50492261)
Aincient media storage device. Currently I only possess one, Loverboy's Get Lucky. :D
On my 4Runner, there is a antenna switch.
i guess they didnt put em on the trucks |
(Post 50492275)
so all the holiday in cambodia tracks must be on MP3, huh.
wait your atenna still works lol i thought all those darn things broke off mine did so i just disconnected the power to it so i dont have to listen to it try adn go up and down all the time
Originally Posted by PoleVaulter95
(Post 50492301)
mine was trail tested and failed. |
(Post 50492260)
Thanks fullman.
Mine doesn't go down when I turn the radio off. 17 years old, I guess you're gonna have that kind of stuff. At least it goes down when i turn the ignition off. Next time I pull the dash off, mebbe I'll try to figger out if it's the radio or the relay. Cheers |
