headlight help
i have looked but noone has the same issues i got i have a 1992 yota the lo beams work hi beam or flash do not i got power to all three wires when the brights are on i am lost here any help
kind of tough to read with no punctuation.
Let me see if I got this right. 1. The Low beams work 2. The high beams do not work. 3. Pulling back on the indicator switch to flash the highbeams also does not cause the high beams to come on 4. You have power in the wires where it should be. Are you sure the second filament in the headlights (The high filament) works? Looks closely at the bulb (with power off) to see cracks, burnt, discontinuity in the bulb.. You can check resistance on the bulb, using an ohm meter.. as long as it isn't infinity (open circuit) the bulb isn't burnt out.. IF there is power going all the way to the headlight, the problem is most likely with the light itself. Post some details on your truck too.. Year, truck or 4runner.. the more background info the easier it is to get to the bottom of this.. |
it is a 1992 pickup 4wd 3.0 auto i just swapped out both headlight thinkin that was the problem i hooked the old light up to a battery and they worked on hi and low sorry for not puttin all info on there was in a hurry on break at work
There is a relay for each headlight under the hood in the main fuse panel.. Maybe where to check next..
http://i271.photobucket.com/albums/j...lightrelay.jpg |
i will try that tomorrow when i can borrow an omn tester. i hear the relay click when i flip on the brights. i read somewhere that if you go dims or brights either one then the relay is working am i correct. i looked in the main fuse panle and there is only 1 relay is that normal
any more help
I can't confirm what you said about the relay.. If the relay has power, that means the switch is working.. there's a break in the wire somewhere between the relay and the headlight.
When did you notice the high beams didn't work? Was it after a car wash? was it after you put new bulbs in? |
they havnt worked since i got the truck. is there surposed to be power to all three wires on the plug when his are on?
check your fuses.
I did the.4wheelcrawler fix with thebswitch but it didnt help any more help
