YotaTech Forums
-   86-95 Trucks & 4Runners (https://www.yotatech.com/forums/f116/)
-   -   going to replace head gasket (https://www.yotatech.com/forums/f116/going-replace-head-gasket-88168/)
hirsche23 Jun 15, 2006 12:10 PM
So I am going to replace my HG on the 89runner 22-re.IT was done recently by the previous owner. He had the head machined and put he new HG in himself.Now it is blowing white smoke and losing coolant after only less than 1 year of use.What would cause the hg to go again and what things are important to do so this doesn't happen again.Thanks.
Elton Jun 16, 2006 07:38 PM
there alot of things that can cause a hg to blow
kyle_22r Jun 17, 2006 02:01 AM
if he used a generic felpro type head gasket, it could be just bad luck. these gaskets don't work well on our engines unless the finish on both the block and head are perfect. toyota's gaskets(as well as rock and some others) employ a steel slip plate on the head side that allows the head to expand freely without harming the gasket. much more forgiving, if a couple bucks more.
clint Jun 17, 2006 07:23 AM
he might noy of replaced the 10 head bolts,in which i have read that they are not reusable something to do with the stretching of the metal i think, you can pick them up from toyota for $15.
hirsche23 Jun 17, 2006 01:16 PM
I know he reused the head bolts(crap) and did get the head machined,so I am going to get the hg from toyota as well as new bolts and hope that it solves it.
kyle_22r Jun 17, 2006 07:59 PM
the head bolts are reusable on a 22R engine, but i definitely wouldn't hesitate to replace them if they were pitted or in bad shape otherwise.
Elton Jun 17, 2006 08:42 PM
just get all your stuff From engnbldr
clint Jun 19, 2006 11:57 AM
i misunderstood the toyota parts person they are actually between $10 and $14 dollars a piece so i called around and was unsuccessful finding anything cheaper.however engnbldr sells a headgasket set with the bolts for $60 u.s. still cheaper then toyota.i am going to contact engnbldr today to see if i can just order the headbolts.the ram is a unbelievable river i caught my first cutt there i also purchased my 86 runner to bush bash on the ftr and your right go oilers go.
