YotaTech Forums
-   86-95 Trucks & 4Runners (https://www.yotatech.com/forums/f116/)
-   -   Did a compression test. (https://www.yotatech.com/forums/f116/did-compression-test-209650/)
Beaniam 04-14-2010 05:43 PM
Didn't expect numbers this good. Test done with all plugs out and the engine at operating temp.
165-170-170-165
245k miles on an untouched 22re bottom end. Engine has been hydrolocked once. Has always had a cold knock (could be piston slap) and has a very slow external water jacket head gasket leak. I've always put off doing a test because I feared the worst.
jsn_stockard 04-14-2010 05:57 PM
Crazy results with that many miles, and considering it's been hydro'd thats lucky
boxer.fan 04-14-2010 08:16 PM
When I did mine I was at 155 all the way across. I have 121k miles. Carbon build up will also create higher compression numbers.
