YotaTech Forums
-   86-95 Trucks & 4Runners (https://www.yotatech.com/forums/f116/)
-   -   Cable driven speedometer issues (https://www.yotatech.com/forums/f116/cable-driven-speedometer-issues-307607/)
Amethyst_Spark May 4, 2019 11:45 AM
Ok so I’m new here. I’ve been fallowing some discussions on here for a while but my question has yet to be answered. My speedometer cable quit working I tried replacing the gauge as well as the cable still having the same issue also my tach isn’t working. I’m driving a 91 with a 22RE and a 5 speed 2wd. Please help
Amethyst_Spark May 4, 2019 11:59 AM
Edit
I did get a new cluster out of an SR5 because I wanted more than just idiot lights I followed this thread with installing it
https://www.yotatech.com/forums/f116...06/index6.html
old87yota May 4, 2019 03:03 PM
Does the speedometer work at all?
With the speedometer cable, the speedometer and tachometer are independent of each other.
Did you confirm that you have a wire in the wire harness for the tachometer? If there is no wire for the ignition signal, the tachometer will not work.
:safari:
Amethyst_Spark May 4, 2019 07:09 PM
:safari:
im not sure how to check for that. At this point I’ve tinkered with it a bit and I’m pretty sure the Speedo issue is actually inside the transmission. I’ve been looking around for a guide on how to open up the housing where the cable feeds into the transmission as well as replacement parts but I have yet to find anything. Correction I found one thing and that was the speedometer gear inside the transmission that turns the cable is held in place by retaining springs? Not sure what to think of that let alone how to fix. Any input would be helpful. Especially about the tachometer. I would love to get that working. I thought the sr5 cluster would be plug n play according to this thread. https://www.yotatech.com/forums/f116...06/index6.html
