Body to frame mount bushings.
Hey yall,
I'm getting a loud clunking noise in my 1993 pickup when I am going over any uneven terrain. I believe the problem is the bushing I attached pictures of. The truck has a 3 inch body lift. I'm looking for suggestions on where to buy them and if anyone has replaced them before and can share there experience before I get into it. Seems like it shouldn't be to much of a pain. https://cimg8.ibsrv.net/gimg/www.yot...fe7fe7cb3c.jpg https://cimg0.ibsrv.net/gimg/www.yot...4c322d29a6.jpg |
my professional recommendations is that the amount of body lift you install directly correlates to how much axe body spray you use throughout the day. 0-1" is none, anything over that is 8 cans. ditch the 3" body lift and make Toyotas great again. you can get great new poly bushing sets from energysuspension for about 100 bucks, or you can get a good custom kit from 4Crawler with new hardware for a little more. I have run 2 kits from 4crawler and his stuff is top notch.
Originally Posted by keycw
(Post 52423666)
The truck has a 3.4 in it and from my understanding it needs some lift for clearance for the intake? I'm not sure. I'm not opposed to getting rid of the lift. Could I still run my 32" tires? I just got the truck and definitely wanna make it right. What exactly are the negatives of a body lift besides the stench of axe body spray and the sticky residue of monster energy drinks?? |
Originally Posted by LoneStarr404
(Post 52423624)
Hey yall,
I'm getting a loud clunking noise in my 1993 pickup when I am going over any uneven terrain. I believe the problem is the bushing I attached pictures of. The truck has a 3 inch body lift. I'm looking for suggestions on where to buy them and if anyone has replaced them before and can share there experience before I get into it. Seems like it shouldn't be to much of a pain. https://www.4crawler.com/4x4/ForSale...l#PolyBushings |
(Post 52423669)
If I ditch the lift what should I do with the cases of axe I bought?!?! That stuff ain't cheap buddy!
The truck has a 3.4 in it and from my understanding it needs some lift for clearance for the intake? I'm not sure. I'm not opposed to getting rid of the lift. Could I still run my 32" tires? I just got the truck and definitely wanna make it right. What exactly are the negatives of a body lift besides the stench of axe body spray and the sticky residue of monster energy drinks?? now, with the 3.4 swap I could be convinced that there were clearance issues but I don't it would be drastic enough for a 3" body lift. maybe someone on here can chime in that's done the swap. ive seen a few trucks with that swap and their body to bumper ratio was still good. fitting 32s on a stocker with no lift would rub, but you could get away with those tires and MINIMAL lift, like maybe a few cranks on the torsion bars and a small block or shackle. as for all the monster drinks, I recommend maybe switching over to Bang, they don't have as much crap in them. |
(Post 52423674)
aside form looking god awful, you've created a weakpoint between the frame and the body that shouldn't exist, you've stretched your coolant lines, created extensions in gearbox linkage that should be there, made a huge gap between your bumpers and body (also falls into the looks bad category), and to be blunt its a cheap way out of doing something. do it the right way and invest in your suspension. you gain tire clearance with a body lift but gain nothing for wheel travel.
(Post 52423676)
Eventually I will be getting into the suspension but funds will be holding that off for a bit. I think I will just order the bushings from 4crawler for now.
(Post 52423685)
you cant specify on his site what length bushings, he will cut any length you want. you can also ask for hardware or upgraded hardware. read carefully the site isn't the most up to date thing in the world.
I think I got them ordered right. I emailed them first. Quick response. Definitely a little confusing. |
I have the 3.4 swapped into mine and I used a 1 inch body lift (4Crawler's kit) and it clears. I have read that the 2nd Gen may not require a body lift at all.
So I got the bushings and hardware quickly. Everything looks good. I'm fighting a couple of bolts though and I was wondering if yall had any advice on getting them out.
It's the bolts on the front cab body mounts holding the bracket to the frame. I cant get a socket on them and a open end wrench barely holds. Worried about rounding them. Since I have new bushings can I just get it red hot and hopefully its loose enough to twist out of there?? https://cimg0.ibsrv.net/gimg/www.yot...8e6f115c9b.jpg |
I think you don't need to remove the bolt in the left.
The procedure is similar like in this video (but no lift of course), I believe: But lets wait for the experts advice. |
Originally Posted by SomedayJ
(Post 52424173)
The procedure is similar like in this video (but no lift of course), I believe: https://www.youtube.com/watch?v=cKgqam0VhjA But lets wait for the experts advice. |
