Originally Posted by camo31"10.50"
(Post 51276950)
and my 22r is slow as everything...although it does better now than it did before (at least the RPM range is a LOT better with the 261*) it's still a frickin dog...idk how you guys are able to go 75-85 with ur 22re's on 31" tires..
mine MIGHT do 80...if it's running TOP NOTCH..and i get a LONG LONG LONG running start at it..lol |
Well the truck i just bought is a 1994 toyota pickup 4wd with 33 inch trail blazers and a 4 inch suspension lift all the way around. Im running a Brand New 22RE with a Brand New Transmission, and Brand New 411 gears in the front end and the rear end and i get 19 miles to the gallon easy.
very sweet mileage with those giant tires.
what would be the best gearing to get, for primarily highway mileage, if that is what you do most? |
uhhh I could be wrong, im not exactly sure. but I believe 4.88s with a 5 speed and 33s and doing 65 in 5th gear keeps your truck right around 2.5k rpms? someone wanna correct me on that? I know 31x10.50s, 4.10s and a 5 speed in 5th gear keeps me at 2.9k rpms
Originally Posted by MaK92-4RnR
(Post 51298399)
go on a diet
Take off the rear axle and spend a year and a half putting off rebuilding it. I've saved boatloads on gas by having people drive me places!
Originally Posted by kawasakimoto_7
(Post 51276350)
open up the exhaust.. with like a turbo muffler from borla or something like that.. open intakes are good.. change your oil, air filter, spark plugs and all that and those can help with gas mileage
https://www.yotatech.com/forums/f116...l#post51272909 Also helps to make sure the motor is fully tuned and running as perfectly as possible. Make sure EGR is working, the O2 sensor is a Denso direct-fit in good shape, clean the throttle body and run Seafoam if necessary (do this before changing O2 sensor), use stock Denso plugs, dealer cap, rotor and wires, set timing to spec or a couple degrees more advanced, run a bottle of Red Line SI-1 Complete Fuel System Cleaner through the tank - has the most polyether amine of any in-the-tank injector cleaner. Make sure no vac leaks (as some have mentioned) and make sure ECT, TPS and VAFM are all in spec. If you haven't adjusted valves in a while, that should be done. Running higher pressure in tires will reduce rolling resistance but don't go overboard. |
anyone know if I can change my ECU from a CA to Fed without issue so I can loose the 2nd O2 after the cat? also thinking about fitting an elec fan. my shroud broke so thought Id spend $30 more and change the entire fan... my best mpg was 17 but then I had some valve seat issues; not sure what caused it but trying to make sure it doesnt happen again.
3L auto 4x4 |
also, can anyone tell me what my timing should be? the books say read the stickers on my hood but I dont have any stickers.. NON not even and A/C or vac line sticker. how much difference is there b/w running 10 to 15 degress?
thx |
Originally Posted by spitfire4
(Post 51674436)
thx |
My best mod for Mpgs? Driving Slower.
i get right around 19-20 to the gallon in my stock 22re, 94 runner, 31" at, 4.56s, however i drive her. seems to get around the same or slightly less highway mileage at above 3000 some rpms. she will do 85 fine and still had more to go. kinda scary to go above that though
i make sure to keep my plugs, wires, and air filter pretty fresh and just recently switched to mobil 1 so hoping to squeeze a little more out her |
TPS adjustment so far did 3 22re trucks and big improvement on adjusting and replacing the bad ones.
I have a question... Just filled up and figured out I'm getting 12.25 mpg city and hwy mixed. This is not ok for me... I just had a new rebuilt 3.0 put in. I have about 250 miles on it so far. I have a 4inch lift and 33 inch tires. On other thing I have done is a cherry bomb muffler. Otherwise totally stock. I need to improve this my
By 3 to 4 in the city and I'd like to get 18 to 20 Hwy. Should I add a drop in K&N? Downsize the tires to 31's? Any other suggestions? |
On my veezy, which has good compression, is nearly perfectly tuned, has a K&N Filtercharger intake, Borla Turbo muffler and 2.25" cat back, 30x9.5 tires, no lift and a camper shell, only gets 19 highway under ideal conditions. It used to get 24 highway, but with the alcohol they're adding these days it came way down.
So. Reducing tire size probably would buy you a mile or so per gallon, and returning to stock height might help, too. Running on the high side of tire pressure, tuning the motor as nearly perfect as possible will help too. The K&N intake didn't do ANYthing for mileage or power when I installed it in 1996. Nada. I saw a big improvement from the exhaust, tho. Whether the exhaust would have given as big a benefit without first opening up the intake, IDK. I think probably there is almost nothing to gain on the intake side, at least with the stock air meter. One thing that would help a lot is burning no-ethanol fuel, if you live near a source. This site maintains a list of stations: http://www.pure-gas.org/index.jsp |
I have an 88 Single cab with a woodbed, has a 92 22re gets awful mileage around 10-12, i have 33x12.5 TSL's. , that i run 30PSI in max is 35..I have a broken vacuum line elbow on my Throttle body. Problem?
Originally Posted by sb5walker
(Post 51675864)
So. Reducing tire size probably would buy you a mile or so per gallon, and returning to stock height might help, too. Running on the high side of tire pressure, tuning the motor as nearly perfect as possible will help too. The K&N intake didn't do ANYthing for mileage or power when I installed it in 1996. Nada. I saw a big improvement from the exhaust, tho. Whether the exhaust would have given as big a benefit without first opening up the intake, IDK. I think probably there is almost nothing to gain on the intake side, at least with the stock air meter. http://www.pure-gas.org/index.jsp |
Originally Posted by Blackulua
(Post 51674759)
I took the seats out of my runner and put them in my accord... getting 32mpg now instead of 15....lol
