86 carburetor problem
I have an 86 Toyota 2wd truck. I've had it stored since my son went in the military. I drive it periodically. It's been stored longer than usual. Its not getting fuel, it turns over and if I add gas to the carburetor it runs. I disconnected the fuel pump and it's pumping fuel, reconnect but none will go into the carburetor. I sprayed the crud out of it with carb cleaner.
It ran like a top 4-5 months ago. The fuel pump was replaced at some point, not sure when but we've had it 5 years, 3 of those it's been stored off and on. |
In which direction do you have non fuel stuff coming out of the line and what kind of stuff?
My first guess would be fuel filter is clogged up. |
