YotaTech Forums
-   86-95 Trucks & 4Runners (https://www.yotatech.com/forums/f116/)
-   -   3vze code 71 (https://www.yotatech.com/forums/f116/3vze-code-71-a-308091/)
mike250 Jul 11, 2019 08:01 AM
3vze code 71
So i was driving my truck and and it just died all of a sudden. I can turn it on but it only runs for about 2 seconds. If i mash the gas pedal i can get it to run longer but it still will eventually shut off. I checked the cel and got 7 blinks then 1 blink. The cel was on for a quite some time a while ago but i thought i had checked it and thought it had to do with a bad catalytic converter. but now it is giving me a different code. i don't know maybe i misread the code, i have no idea. it would store two codes at once right? i dont know, but anyways fsm says it is a EGR System Malfunction and gives me these probable causes. if you were in my shoes where would you start? -thanks :)
• Open in EGR gas temp.
sensor circuit
• Open in VSV circuit for EGR
• EGR vacuum hose discon–
nected, valve stuck
• Clogged in EGR gas passage
• ECM
Dom91 Jul 11, 2019 12:20 PM
I'd start with vaccum leaks
mike250 Jul 11, 2019 01:04 PM
ok so i unplugged the throttle position sensor and vafm and the truck started and idled fine. but as soon as i plug either of those back in it dies. :dunno:
Dom91 Jul 11, 2019 01:23 PM
What if only one is unplugged?
mike250 Jul 11, 2019 01:43 PM
it only runs with both unplugged. if i plug in the vafm it will die. if i plug in the tps it will die. however i took cover off the vafm and increasingly turned the dial thing counter clockwise until i was able to plug the vafm and tps back in and have it continue running. i just have to hold the dial in a certain position to keep it running, as soon as i let go it dies.
