That looks great! I'm excited to replace mine as well. I just sent the shifter lever of a t-case through the side of mine. I'm probably gonna use plywood and build a sub box into the side by the roll bar, and move the 6x9's to where the little storage areas are by the back seat.
RAD4Runners Rear Body Panel Storage...
I cleaned up the Inner Rear Body Panel some more by tucking harness as tight as possible behind the middle beam, to use as storage. Will replace quarter panels with ones that will allow access to the whole width of openings.
I have 1/4-inch polycarbonate sheets but I think foam-backed and vinyl-wrapped wood panel will be lighter and provide better noise insulation. Pics taken while in-process. I deleted rear windshield system. May re-purpose windshield washer/pump into water storage / pump system. Bottle jack storage and handle extension rod will be re-installed. https://lh3.googleusercontent.com/pS...=w1328-h747-no https://lh3.googleusercontent.com/CD...I=w421-h747-no https://lh3.googleusercontent.com/0m...=w1328-h747-no https://lh3.googleusercontent.com/v4...0=w421-h747-no https://lh3.googleusercontent.com/4U...=w1328-h747-no https://lh3.googleusercontent.com/5g...=w1328-h747-no MADE REPLACEMENT PANEL/DOOR https://lh3.googleusercontent.com/6u...=w1428-h803-no PANEL / DOOR Used black Plexiglas that I have lying around. If it turns out to be too fragile, I'll replace with clear Polycarb that I also have that I'll paint black. (D-Ring tie-down is reflected on glossy material) https://lh3.googleusercontent.com/Rn...=w1428-h803-no NEEDS A LATCH MECHANISM It will latch on to lip of body panel. I don't need it to be locking, yet. I a want minimal, low-bulk, low-cost solution. Would appreciate your inputs. Front section beside the roll-bar will be next. Same concept. keywords: rearbodypanelstorage |
Roll-Bar Storage Pouch
To utilize area bounded by the roll-bar and the wheel-well...
BTW: NOT A GOOD IDEA TO STORE FIRE EXTINGUISHER ON ROLL-BAR. In case of a fire, most likely in engine compartment, power would probably go out and leave rear window inoperable for accessing extinguisher. I plan to relocate, maybe along transmission hump next to passenger's left leg. https://lh3.googleusercontent.com/AY...=w1380-h776-no Dimensions in case you want to make your own. This is for the front and sides of the pouch. Just make one that's 11" x 9.25" x 12.625" x 15.5" (PLUS your choice of seam width) for the rear panel. (I used 0.25-inch for seams. Your option to use different width.): https://lh3.googleusercontent.com/yX...A=w940-h776-no Made template out of Shopping Bag... (Pls note that I revised dims to show 0.75 inch for the "Draw-cord collar" at the opening just for flexibility.) https://lh3.googleusercontent.com/xM...=w1380-h776-no I prefer to hand stitch seams. https://lh3.googleusercontent.com/u6...=w1380-h776-no https://lh3.googleusercontent.com/d3...=w1380-h776-no https://lh3.googleusercontent.com/56...=w1380-h776-no Doubled Up Hook side of the velcro straps... https://lh3.googleusercontent.com/sr...=w1143-h776-no Put "Loop" patches on the roll-bar to help keep pouch in place: https://lh3.googleusercontent.com/48...=w1380-h776-no https://lh3.googleusercontent.com/Yt...=w1380-h776-no https://lh3.googleusercontent.com/gg...=w1380-h776-no https://lh3.googleusercontent.com/my...=w1380-h776-no VOILA!... Easy to remove to access more storage space in body compartment behind it. Right now I just have thick foam that's my template for final body panel replacement (possibly vinyl-wrapped plywood). https://lh3.googleusercontent.com/wP...=w1380-h776-no |
Excellent use of storage space RAD!
And a handy place to store the FSM too! :great: :safari: |
just to let people know .. we build fiberglass replacements .. much better then the OE plastic pieces .
https://cimg7.ibsrv.net/gimg/www.yot...31bfab51e7.jpg https://cimg6.ibsrv.net/gimg/www.yot...c8a253138d.jpg |
Originally Posted by slacker
(Post 52399663)
stupid wait time ..
but I am looking for my own building .. I am relocating , so hopefully I will soon be able to elevate the back order situation . |
I have rolled around the idea for a long time and haven't decided on a good solution. My best suggestion is decide what you need most. Speakers? Subwoofers? Storage? Good looks? How much time/vs money? I think the diamond plate looks awesome but, cost of material and ease of working with it has kept me away. I NEED to have decent sound but I can't afford to lose much storage space. I haven't built it yet but, my goal would be to use the open body panels and some doors to create as much storage as possible. No one solution is best, you really have to evaluate your needs. For me this is a family adventure vehicle so it needs storage.
Originally Posted by stovetop36
(Post 52399820)
... I can't afford to lose much storage space. I haven't built it yet but, my goal would be to use the open body panels and some doors to create as much storage as possible. ..For me this is a family adventure vehicle so it needs storage.
(Post 52399759)
stupid wait time ..
Originally Posted by Bad Karma
(Post 52399916)
I wanted to pull the trigger on a set of these, how many weeks in "stupid"? Or are we talking months?
I'm actually trying to replace a missing one... The one I have is in great condition, but I haven't had any luck finding a driver-side panel yet. Just as soon replace them both with fiberglass ones if I can get them.
Yeah, those fiberglas ones are very nice!
(Post 52399916)
Originally Posted by se7enine
(Post 52399969)
If you already have some panels you could just coat them with a fiberglass resin to stiffen them up.
(Post 52399985)
(Post 52396971)
https://lh3.googleusercontent.com/Rn...=w1428-h803-no NEEDS A LATCH MECHANISM It will latch on to lip of body panel. I don't need it to be locking, yet. I a want minimal, low-bulk, low-cost solution. Would appreciate your inputs. Is this the bsic idea on the latch? https://www.ebay.com/itm/Craftsman-T...QAAOSwx5RanL9C |
I prefer the OEM look but this guy on Facebook makes these out of metal for $200/pair. He also makes door cards and tailgate panels. People seem to love his work. You have to join Facebook to see this. You can join with a fake name. Eddie's Custom Designs
https://www.facebook.com/TOYOTAS.4.L...egory_pyml_rhc |
I prefer the OEM look, too, but that guy makes some really nice stuff! I'm already neck-deep in making new door panels and side panels, so I'll just go with the fiberglass ones from Slacker. My 4Runner is a trail vehicle, so the wait time isn't really an issue for me. You'll be hearing from me, Slacker, very soon.
Originally Posted by L5wolvesf
(Post 52400008)
Nice work RAD
Is this the bsic idea on the latch?... .Craftsman-Tool-Box-Lock-Chest-Key-Storage-Truck-Safe-Cylinder-Chrome But debating whether to use keyed or one with heftier twist handle. Although I could simply leave the key on the lock/latch Then, I'll set ut up so when I want to leave it open longer, like when I'm working on something, Ill hang it from my "tie-up" points right above.
Originally Posted by Nervo19
(Post 52400029)
(Post 52400035)
Yes:)
But debating whether to use keyed or one with heftier twist handle. Although I could simply leave the key on the lock/latch Then, I'll set ut up so when I want to leave it open longer, like when I'm working on something, Ill hang it from my "tie-up" points right above. |
2 Attachment(s)
(Post 52400038)
I was trying to figure out what it would be called without a lock and came up with
https://www.amazon.com/Thumb-Latch-C.../dp/B007JGWVDM https://cimg6.ibsrv.net/gimg/www.yot...92f51162ed.jpgCamco Cam Cabinet Latch |
