weber adapter plate which one
I just got 1985 Toyota mud truck, with no history from previous owner. bought a weber carb w/adapter on ebay. adapter doesn't fit . bought a transdapt from summit same as the other one. the intake manifold passenger side bolt pattern has a 2 7/8 oc bolt spread, drivers side has a 2 1/4 oc bolt spread. the adapter part no is 2181 . the valve cover says 22r, Thanks in advance for any help
Hit up LCengineering.com they got what you need
Sent from my ADR6400L using YotaTech |
Hey man LC has a spiral adapter go to there site and you will find it my weber leaked bad around the base from the weber adapter and I put the LC spiral adapter on and it is great and mite have gotten a few more HP
Thanks they hooked me up. As it turns out I have a 20 r intake on a 22r engine
Originally Posted by Dale Rosales
(Post 52072618)
So does the LCE Spiral.
