YotaTech Forums
-   84-85 Trucks & 4Runners (https://www.yotatech.com/forums/f115/)
-   -   Rough idle (https://www.yotatech.com/forums/f115/rough-idle-241688/)
cazador Sep 20, 2011 06:14 AM
Rough idle
The truck runs fine while driving, but at idle it's rough until I tap the gas and it smoothes it self out.
This is what I have done.
  • Checked EGR valve
  • replaced BVSV valve
  • 3 cans of Seafoam
  • replaced o2 sensor (but need to replace again used the Bosch)
Any ideas before I go out and buy a new EGR valve?
4Crawler Sep 20, 2011 07:55 AM
Guessing this is a 22RE engine?
Check your TPS idle setting:
- http://www.4crawler.com/4x4/CheapTri...roubleshooting
GenXr Sep 20, 2011 08:02 AM
How old are your spark plug wires, cap and rotor? I had rough idle at start up on rainy wet days....a little tune up and its all good.
cazador Sep 20, 2011 09:03 AM
I did do a full tune up and in the last year I had.
new
timing chain
water pump
Oil pump
cazador Sep 20, 2011 09:05 AM
Yes it's a 22re.
ant27 Sep 20, 2011 06:06 PM
can not use bosch o2 sensor? and i fixed my idle with a valve adjustment
