Motor swap - 22R to 22R advice
Hi you guy I'm new to this forum
I just got a 1985 Toyota 4x4 truck. It has a blowen 22r it not a 22re. The motor has two hole in the block. im guessing it throw a rod or two lol. Well my uncle is giving me a 1984 22r but it need a rebuild. I bean reserching I only found that the exhaust port on the 1984 22r are sqaure and the 1985 were pear. ˟ I trying to find out is that the only ˟differnt between the two?˟ My plan to rebuild the 1984 22r. Bore the piston .020 run DOA Metal backed guides with a rv crawler cam. ˟I'm going to buy a rebuilder kit off of˟engnbldr.com I herd good thing about there rebuild kit. I'm going with them. Is there more info do that I need??˟ PLEASE CORRECT ME IF IM WRONG IM A NEWBE THANKS |
Welcome to Yotatech :D
Ignore my previous comments. Drink more :coffee: :wabbit2: |
Originally Posted by waskillywabbit
(Post 51745515)
Rebuild one motor using the two and reuse EFI :wabbit2: I think he means the truck was originally a 22RE truck but is now going on it's third engine???? I have posted numerous times on here about the differences between all the motors. |
I like tater tots :hillbill:
:wabbit2: Time for more :coffee: I missed that one completely |
Watch out with too much coffee, you know how I get. I'd hate to see you go pirate on us. :lof:
Arrrrrrrgh. :hillbill:
Fixed title and moved to 84/85 section. Back to :coffee: :wabbit2: |
Well I hope I read that original post right since you changed the thread title. lol. But read it again and it seems as though I was right. But who knows.
Thank you for have me on yotatech.
My truck was built April 1984 but the pink slip say sold in 1985.I know the motor is not efi it has a Carb on it. |
ok then it should be a direct swap. Exhaust ports should be the same between the two motors, if they are not then you have the wrong year on one of the motors. You said the truck was originally an EFI truck? But has a carb'd engine in it and the engine you want to put in is an 84 engine?
Sorry for the miss understing my truck was never EFI. Yes I want to put a 1984 22r. I bean researching every body said they are the same engine:-)
yup same engine as long as the exhaust ports are round. Just slap the thing in and go. :great:
Here is those differences: http://www.lcengineering.com/TechNotes/?techid=49 |
Thanks you bro for the info :-)
