YotaTech Forums
-   84-85 Trucks & 4Runners (https://www.yotatech.com/forums/f115/)
-   -   fuel injection problems (https://www.yotatech.com/forums/f115/fuel-injection-problems-288568/)
ej_jenkins Apr 28, 2015 10:32 AM
I have an 85 truck 22re and can't figure out what's wrong ... I'm not getting any fuel threw my injectors but I'm getting fuel to the fuel rail and when I put a test light to any of the injector plugs there is constant power should it be pulsating
Terrys87 Apr 28, 2015 01:17 PM
I get 8-12 pulses https://www.yotatech.com/forums/f116...t-22re-270857/ when using this LED. If you are getting pulses, it could be the crimps are corroded. The computer can be sending the signal but the crimps can keep the signal from passing.
Other things I check https://www.yotatech.com/forums/f199...l#post51897320
Another thing I would check for is if the injectors are clogged.
wyoming9 Apr 28, 2015 02:04 PM
I am pretty sure a test light won`t work if that is what you meant. .
What are they called Noid lights for testing if the injectors are firing like they should.
