dont do front digs with 38's aired down on asphalt
BOOOM!!!
CRAP!! http://i23.photobucket.com/albums/b3...4/599e6413.jpg http://i23.photobucket.com/albums/b3...4/a25d4659.jpg http://i23.photobucket.com/albums/b3...4/3ae592c0.jpg at least i was in my own driveway :bang: |
Wow that is something I have never seen before :scared: :eek2: :eek2:
Surely you weren't surprised when that happened...
I take it you're running longfields. Nice to see the 5.29's teeth held up.
its possible that i did shear a tooth off which got bound up in the ring/pinion and BAM, i guess that its better to break in the driveway vs. the trail :bang: |
Quality carnage...
Call me a noob, but what's a front dig?
Is that one of those "NW" terms? |
So...
What's a front dig????????? |
front dig...
when one shifts there twin sticked transfer case to front wheel drive (low range) in order to pull the front end. (usually to make a hard turn were you dont want the back end PUSHing you forward |
:bang:
And I thought I was hardXcore!!! |
so its somewhere between crossing a ditch and front wheel drive? :think:
You too huh? The front wheel drive thing makes more sense to me.
So I was wrong...
Sorry guys. |
Originally Posted by superjoe83
yes, but just the treated ringed stockers
cool carnage...
Originally Posted by snap-on
front dig...
when one shifts there twin sticked transfer case to front wheel drive (low range) in order to pull the front end. (usually to make a hard turn were you dont want the back end PUSHing you forward SuperJoe - what are you running for a tcase? |
If anyone could elaborate for the noob...how come this is happening. As far as I understand, you are using FWD in low gear, so the shaft is spinning fast, but why would it break especially on a drive way?
Also, how does having a shaft disconnect cause this? And how does the prototype case help avoid that? |
my rear shaft was out of the truck, 2nd gear low=boom
here are some more pics, i did in fact loose some teeth http://i23.photobucket.com/albums/b3...4/fba023b9.jpg http://i23.photobucket.com/albums/b3...4/4a65ed96.jpg http://i23.photobucket.com/albums/b3...4/5671673f.jpg that brown stuff on the teeth is just some dirt from my fingers |
