Stock furst gen tire size question.
I'm still bone stock, but I was wondering what size tires will fit my truck. Meaning the largest without rub. Anyone have any suggestions?
I believe a 31x10.5 will be the biggest without rubbing.
That's what I thought, but I figured it was worth asking. I knew a guy with 33s on stock and he swore they didn't rub, but I don't really believe him.
depends if you run the stock 15 inch rims.
if not stock. depends on backspace. all depends on backspace.....32s will not rub on a 1st gen on 16" tacoma wheels on the front axle. but will on the rear with articulation to the frame. with backspace tire width is main concern. |
33x10.5x15s with 3.75 backspacing will work.
X2 on 33x10.50s
Sweet, I just realized I misspelled the word first on the thread title.
I currently have 34x15 TSL on mine and im pretty sure its all stock. only time it rubs is a sharp left.
31x10.5 works perfect on my truck. You can put 33x12.5 tires on it with a little bit of rubbing, but without regearing you might as well say goodbye to 5th gear and going highway speeds up hill.
Ok, I've got stock rims with 235/75/15s, will 255/70/15s fit with no clearance issues on the original rims? I'll be dailying this truck so I don't want to throw on 31s or anything huge. I'm currently looking at
http://www.discounttiredirect.com/di...V&rd=15&cs=255 And http://www.discounttiredirect.com/di...5&rd=15&cs=235 What do you think? Thanks. |
