Quick question
My wheel bearings came with a small rubber seal that has a spring around it.
I didn't see one of these when I pulled the whole deal apart and am guessing that the PO missed putting it in originally. That said, I don't know where it would go Anyone have an idea? http://i298.photobucket.com/albums/m...HPIM0083-1.jpg http://i298.photobucket.com/albums/m...j/HPIM0084.jpg (no it's not beat up in this picture, that's just some grease) Thanks for your help! |
extra part
Whats the id on that
No info on the seal or the package
extra part
I was wondering about the inside diameter. Its been awile since I tore my axel down but i think i remeber a seal that goes behind the wheelbearings that you wouldnt of had to remove to change your bearings.. But its been awhile so im not possitive
I think thats the axle seal...
It doesn't fit over the spindle (it might if i force it), and its slightly larger than the diameter of the axleshaft.
It isnt the inner axle seal because they have a metal ring and are much more sturdy than this |
it's not for a 79-83 ...
generic bearings sometimes include "other" parts ... |
Looks like a dust seal to me, but for what i have no idea.
I called the company I bought it off, and they say that it IS an inner axle seal after all.
I was comparing it to my marlin HD inner axle seal and figured that there was NO WAY it was one, but I guess that just goes to show how quality the marlin ones really are |
ohh fronts ? I thought you were talkin rear bearings ?
so you did the front end !!!! .. why didnt you just buy marlins whole kit then ? |
Originally Posted by slacker
(Post 51065840)
so you did the front end !!!! .. why didnt you just buy marlins whole kit then ? I went with Big Country Customs out of Abby They gave me TG rebuild, Marlin HD seals, and Yukon front bearings. No real reason why I didn't go with marlin, and from what I've read the rebuild kits are essentially the same (bearings aside). I asked what bearings they would recommend and they said Yukon, so that's what I went with. got the pass side all dialed up today and hope to start the drivers on Monday (timing with work and college is a little difficult) |
| All times are GMT -8. The time now is 05:33 AM. |
