Brake up grade for 79 pickup-finding parts for 79-80
I have a 79 pickup and was thinking about getting bigger rotors and calipers for the front. I was wondering if anyone has done this and if anyone knows about the set up at wabfab and if it easy to install and works good?? I've heard that the calipers dont fit with most wheels... or if anyone knows of some better rotors and pads that have worked good for you? thanks - Allyn
I have toyota pick up v6 calipers , and landcruiser rotors .. very popular swap and all bolt on . all avaliable at your local parts shop
It's true, some wheels may not fit. I took the Pro Comp Rock Crawler steelies that were on my 4Runner and put them on there, simply cause I wanted to run the KM2's on my '83. Ended up having to use 1.5" wheel spacers for the 4.5" backspaced wheels to clear, though I could've used a touch smaller wheel spacer and cleared, probably. It is pretty dang easy to install, although some people are then unhappy about having more pedal travel with the larger calipers and the stock master cylinder. My master is leaking internally, so I'm upgrading to the 1" master from Marlincrawler since it's recommended anyway. As it is, it still stops really well, even though I pretty much only have front brakes unless I stomp on it.
you need the vented rotors off a 81-87 FJ-60, the calipers off an 86 or newer pickup/runner, and the master cyclinder from an 88 or newer v6 pickup. a dismantler might be your best bet.
This sounds like something I may attempt in the near future as well. Can the originals be used to replace the rear drums? That would be swell if so.
I've never heard of that, most of the kits and brackets out there to convert the rear to discs are for GM calipers and rotors. Search, you might find something.
Originally Posted by thebrick
(Post 51429380)
OR, machine down the outer WMS so a Tacoma rotor can fit over it, and you might get a vented, floating rotor... The math indicates that only for the 79-80 hubs THIS WILL WORK... I just can't do it b/c, hello? Where can one find those hubs?:D 1980 solid front axle vented rotor conversion help |
Originally Posted by JonnyBoy
(Post 51430699)
very common upgrade on a 1st Gen truck, makes a big difference, no kit needed for the front, just get the toyota parts and go for it |
Originally Posted by tried4x2signN
(Post 51437458)
(Post 51429380)
Break upgrade.. HELP!
So i have been doing the big brake upgrade on my 79 pickup and have found that the 79 and 80 pickups need the 76-80 FJ40 front rotors even though most of the things ive read on here and other places say that the 81+ rotors work... so ive been running around to part stores and they have been ordering the 81+ rotors and cant seem to get me what i need. I want to know if anyone with at 79 or 80 pickup has done this swap and what rotors they used and a part number if possible. thanks ahead of time.
79-80 axles are different than 81+ thus your difficulty.
Not sure what will work. Tried Pirate search? :guitar: |
I had a thread about this not too long ago.... basically when I tried to get the 79-80 LC rotors the auto parts stores i tried said that those where discontinued. Only the 81 and newer where available.
Yea ive been to the parts store and they have the rotors i need but they are like 150 bucks a for one rotor. where the 81+ rotors are like 40 bucks im kinda lost on why they are so much more.
Originally Posted by meswoleshane
(Post 51454124)
Totally unrelated but how long ago did you get your truck? Pretty sure I remember seeing it on craigslist about a year ago. Really nice looking.
If you ever decide to get rid of the topper, you just let me know. I'm always looking for a reason to go to Bozeman, and that topper looks really nice. |
Originally Posted by 83
(Post 51454379)
If you ever decide to get rid of the topper, you just let me know. I'm always looking for a reason to go to Bozeman, and that topper looks really nice. Yea the topper is really nice think im going to keep it tho.. if anything changes ill let you know. |
So i dont know if anyone else is looking for these rotors and having trouble but i found this site with some of the 76-80 rotors OEM, Japanese, and aftermarket all pretty expensive but im pretty sure they are the rotors for the 79 and 80 pickup upgrade.
http://www.fjparts.com/brake-brake-d...r-c-23_49.html |
Ok so if I get 81 fj rotors and calipers they will jolt right up to my 82????
Originally Posted by 77FJ40_79PU
(Post 51454976)
Yea i found this truck for sale on a side street in Bozman. I think its originally from seattle. its a good truck and i actually drove it back to Vermont and thats where i am now just havent changed my location on here yet.. to busy workin on the truck.
[quote=adamsbro1;51454995]Ok so if I get 81 fj rotors and calipers they will jolt right up to my 82????[/q
If you have an 81+ pickup you need 81+ rotors and i got 86+ toyota 4x4 V6 IFS calipers... the V6 are the good ones with the 4 big pistons. On your truck you need to press out the wheel studs and then press them back through your new rotors and hubs where as the 79 and 80 pickups just bolt on. here is a good write up i found. http://forums.off-road.com/toyota-su...ted-disks.html |
