83 3rz swap
https://cimg0.ibsrv.net/gimg/www.yot...c6bc597a8.jpeg
I wanted to start a thread to document my 3rz swap into my 83 shortbed, mainly for myself but who knows maybe someone else will find it helpful. I decided to do this swap a few months ago when I found out I cracked the block of my 22r. It was a small hairline crack on the oil pan mounting surface, causing it to leak oil like crazy. So I looked for a 3rz for a long time, they are pretty hard to come by out here in Hawaii. Was really hoping to find a donor truck. ut could only find a backyard engine that was pretty complete. This is what I got: https://cimg5.ibsrv.net/gimg/www.yot...40d81059b.jpeg Then I found a w-56 trans in someone elses backyard. It came with the tcase and front driveshaft still attached (which i dont need) but was missing the shifter handle (which i do need). https://cimg4.ibsrv.net/gimg/www.yot...7a755f675.jpeg Found a bellhousing from the w-59 tacoma trans https://cimg7.ibsrv.net/gimg/www.yot...229d3cddb.jpeg The engine I bought was pretty rough, and the guy didn’t even know what truck it was from or the history of it at all. So I decided to tear it down and rebuild it. https://cimg4.ibsrv.net/gimg/www.yot...d579dd2fa.jpeg https://cimg6.ibsrv.net/gimg/www.yot...a0aa000f3.jpeg https://cimg7.ibsrv.net/gimg/www.yot...59ee060d8.jpeg https://cimg0.ibsrv.net/gimg/www.yot...82f0dc80f.jpeg https://cimg1.ibsrv.net/gimg/www.yot...0a7a672d6.jpeg It waa a good thing I did because I found a small crack in the head near the no.3 cylinder spark plug hole/exhaust valve. After some research I found out this is a common problem on these heads. https://cimg5.ibsrv.net/gimg/www.yot...483624b2a.jpeg So my options were to either wait and try to find another head or buy a new one. It took me long enough to find this one, so I wasn’t too hopeful I’d be able to find another one. Also there would be the chance of finding another cracked one. So I ordered a new one from Clearwater cylinder heads. Complete head with cams for $575. Had the block sent to the machine shop, all it needed was a hone thankfully. https://cimg4.ibsrv.net/gimg/www.yot...37b51094c.jpeg I odered the rebuild kit from LC, complete with water pump and ARP studs. Also got the balance shaft delete kit. While I was waiting for that to arrive I went ahead and cleaned up some of the engine components. https://cimg5.ibsrv.net/gimg/www.yot...51e0d51ad.jpeg https://cimg1.ibsrv.net/gimg/www.yot...d7b413f29.jpeg https://cimg2.ibsrv.net/gimg/www.yot...75dc3512c.jpeg So thats where I am now. Will rebuild the engine next when the kit comes in. After that pull the 22r, clean and paint the engine bay. Need to order motor mounts (can’t decide between chillkat and toyonly), oil pan, and header. |
Badazz! I really want to swap a 3RZ into my 81 once funds become adequate so I'll be following along closely.
What's the plan for wiring harness? Are you going to try to retain A/C? |
Just a warning, when doing the balance shaft delete get a different tap!!! The one they send will snap in the block, its happened on multiple attempts (ask me how I know.) I'm in the middle of a 3rz swap myself, right now I've got the front axle pulled. https://www.yotatech.com/forums/f197...o-tall-303059/
X2 on the tap. Or better yet just weld the hole over and grind flush. Which is what I did AFTER I broke the tap off.
what year 3rz are you using? I have a lot of 83 to 99 wiring info that might be helpful if you’re doing a 2 coil version |
Very cool! I would love to do this some day. So thanks in advance for the build thread!!
Originally Posted by Punjab
(Post 52431598)
What's the plan for wiring harness? Are you going to try to retain A/C? Wiring is gonna be bare essentials, I dont have the donor body harness or dash. Plan is to splice in only what I need to get it running. Still unsure on what to do about VSS. From what I read my 83 dash doesn’t have a VSS like later models. I could get the Marlin VSS adapter, but then I’d be sacrificing the original speedo. Definitely no AC |
Originally Posted by jakey poo
(Post 52431633)
Originally Posted by toy_tek
(Post 52431672)
what year 3rz are you using? I have a lot of 83 to 99 wiring info that might be helpful if you’re doing a 2 coil version My 3rz is either a 95 or 96, distributer type. How different is the wiring from the 2 coil? Will definitely take any help I can get, thanks! |
I'll see if I can dig up the tap, but I think I might've thrown what I had left away.
Still waiting for parts...
Painted the block https://cimg6.ibsrv.net/gimg/www.yot...2e17f973d.jpeg And did a DIY crankshaft polish since the machine shop here couldn’t do it. https://cimg9.ibsrv.net/gimg/www.yot...16a5ea4d1.jpeg https://cimg2.ibsrv.net/gimg/www.yot...2d5def34d.jpeg https://cimg4.ibsrv.net/gimg/www.yot...63625e26c.jpeg |
Cool build / rebuild!
Please excuse my ignorance, but what is the point of deleting the balance shafts? I am just curious! :) :safari: |
Rebuild kit arrived, so I started putting the motor back together.
https://cimg3.ibsrv.net/gimg/www.yot...a77cff5d3.jpeg https://cimg2.ibsrv.net/gimg/www.yot...5e35908cd.jpeg Took two weeks to get the connecting rod bushings reamed to fit the piston pins. Had to send them out to a machine shop on another island! https://cimg5.ibsrv.net/gimg/www.yot...827167a09.jpeg https://cimg2.ibsrv.net/gimg/www.yot...bea761bfe.jpeg https://cimg7.ibsrv.net/gimg/www.yot...41645d991.jpeg Will be pulling the 22r out next, after one last camping trip this weekend. |
Originally Posted by old87yota
(Post 52432189)
Project got put on hold as life got pretty busy. I got engaged though! So the swap kinda came to a halt. But have had some more time to work on it, littlr by little she is coming together.
https://cimg1.ibsrv.net/gimg/www.yot...f927a22c7.jpeg https://cimg5.ibsrv.net/gimg/www.yot...137b5f95f.jpeg https://cimg1.ibsrv.net/gimg/www.yot...ddf6e821b.jpeg https://cimg6.ibsrv.net/gimg/www.yot...9b014720d.jpeg https://cimg5.ibsrv.net/gimg/www.yot...4e8799714.jpeg Chilkat mounts actually worked out pretty good, engine sitting nice and level without any adjustment. https://cimg4.ibsrv.net/gimg/www.yot...3c4386927.jpeg Slowly buttoning up everything bit by bit. Used the radiator and shroud from the 22r, hopefully that will suffice. Ran new 5/16 fuel lines and used the tank from the 83 and a walbro in-line fuel pump. Started wiring up some relays tonight. This is thr part I’ve been dreading as I’m not the greatest with wiring. Got the diagrams from techinfo.com and some posts from forums. I want to keep the 83 wiring all there and add in the engine separately. Going to try and use the ignition switch from the 83 and tie that into the engine...although if I can’t make that work I may end up with a separate toggle switch. Wish me luck! |
Looking good!
You got the big stuff done. Small things like wiring arent hard, they just take time and concentration. you have the harness and ecm for the 3rz? you can always wire a toggle switch to start just to get it fired up so you can get to the next stage of troubleshooting, then splice it into the ign switch later. |
Ya have the ECU and harness but no fuse box so wiring up a few relays and fuses on my own.
The more I try to think about it the more I want to just wire in toggle switches! I think you make a good point. Once it's running I will be more motivated to figure out the ignition switch. So for now I might just put in a couple toggle switches for the fuel pump and EFI relays. The starter switch should still work with the stock 83 wiring and ignition switch I believe. I drew up a little wiring diagram, probably completely wrong. We shall see! |
Real nice work man. What's the plan for the 22R?
Congrats on the engagement! You're way ahead of me on my swap :cry2:
Originally Posted by melk
(Post 52438901)
(Post 52438910)
Just got to reading your build thread now. Lookd like you are doing a lot more than just an engine swap! Good work man keep it up. Just think about how good it will feel when its all done. I think I might cry when I finally hear this engine start up 😂.
By the way, how is your wife doing? |
