YotaTech Forums
-   Vehicles - Trailers (Complete) (https://www.yotatech.com/forums/f108/)
-   -   FS[PacSouthWest]: SoCal 1990 3.0 4wd 31's New Engine, Heads, Colt Cams, etc (https://www.yotatech.com/forums/f108/socal-1990-3-0-4wd-31s-new-engine-heads-colt-cams-etc-295212/)
mad_sb May 28, 2016 11:35 AM
SOLD 1990 3.0 4wd 31's New Engine, Heads, Colt Cams, etc
Hi Everyone. Up for sale is my 1990 4Runner. I have spent the past 2 years bringing this one back and now it's time to let someone else finish the project I started.
I'm selling only because I moved closer to the beach and most 1 bedrooms with a garage are single car only. I'm on a use it or loose it company vehicle lease program, so If i don't lease a company vehicle i loose about 8k per year. Since I have to have a company lease, the 4runner is the one to go.
Please see the "build log" here
This would be an excellent vehicle for anyone that knows how to rebuild an A340h since the trans and 4wd are fully functional. I am including the full tranmission rebuild kit Plus the steels and friction rings. Would also be great for someone that does paint and body. Or someone that wants to turn it into a trail rig etc etc etc. I just don't have room for it any more.
SOLD
Current Mileage: 249,120 (7/02/2016)
Here is my build summary. Everything on this list has been done in the past 26 months / 8,500 miles
Engine:
  • Full rebuild at 240,787 miles (smog mileage 6/14/2014)
  • New pistons, Crank, Water pump, Oil pump, timing set, thermostat, etc
  • All hoses belts, lines replaced including the metal coolant lines
  • Updated "flame thrower" injectors
  • New Distributor
  • AEM wideband feeding the ecu a narrow band signal
  • OEM 02 sensor in place and powered for smog check
  • 7mge cold air intake (stock intake also, quick easy swap for emmisions)
  • Denso fuel pump, Fuel Filter, FPR, and engine side Supply Line
  • Flex-a-lite 674 cooling fan and shroud (3/22/15) [350 parts]
  • Perfect Power SMT8 ECU
  • Ngk plugs and wires
  • Legit smog, very low numbers, 10/31/15
Cylinder Heads:
  • October 2015
  • New DNJ castings
  • LCE Street Performer Valve SPrings, seats, and retainers
  • Colt (sea2sky / weasy) cams
  • L&R machine prep, 3 angle valve job, assembly
Full Exhaust:
  • Dough Thorley headers
  • 3-bolt flanges on Headers, Y-Pipe, Catback
  • Walker CalCat (Cali smog legal)
  • Dynomax muffler
Electrical & Starting:
  • Boyle Future Tech Supra Alternator upgrade
  • Ignition Circuit Relay (Auto's did not use a relay from factory)
  • Grounding and Power upgrades
  • Toyota Reman Starter
Braking:
  • Reman front callipers
  • New rear wheel cylinders
  • New front rotors
  • New front soft lines
  • Hawk lts front pads
  • New master cylinder
  • New rear pads
  • Re Adjusted Load Sensing Valve
Suspension and Steering:
  • Rancho rs5000 shocks all around
  • Upper and lower ball joints
  • Both steering arms
  • Steering damper
  • General grabber AT2 31x10.5 on black stock wheels
  • New tie-rods and adjusters
  • Alignment
Airconditioning:
  • Completed May / June 2015
  • New R134 compressor, condenser, receiver, dryer
  • New High and Low pressure lines
  • Thoroughly cleaned evaporator and box
Interior:
  • Replaced sunroof casset (LKQ) and cleaned drains
  • RA-Mat roof doors and rear cargo area
  • Closed cell foam roof doors and rear side panels
  • Sony MEX-N5000BT Head Unit
  • Qlogic Q forms QL-K4002C291
  • Front and rear seat caltrend seat covers from GT Covers
  • Full carpet set from stock interiors (includes the cargo area)
  • Gray Interior panels (LKQ)
  • New lift gate motor
Misc Not Installed but Included:
  • Full Transmission rebuild kit, including steels and friction material
  • Full Urethane Suspension and Sway Bar Bushing Set
  • Stock intake (quick swap for smog)
  • tune for stock intake (same tune and intake from last smog)
  • Laptop with perfect power tuning software (core i3 lenovo)
  • Factory Front Skid Plate
  • Various spare parts, plug wires, gaskets, starter etc
  • BNIB PPI PH2.65s shallow mount 6.5" Component Speakers
  • BNIB Soundstream Rubicon 4.600 amp
  • BNIB amp wiring kit
https://cimg7.ibsrv.net/gimg/www.yot...bcacf92c60.jpg
https://cimg6.ibsrv.net/gimg/www.yot...ea0dffd719.jpg
https://cimg1.ibsrv.net/gimg/www.yot...4d5f84b3ed.jpg
https://cimg4.ibsrv.net/gimg/www.yot...7023fc752d.jpg
https://cimg6.ibsrv.net/gimg/www.yot...f634657edd.jpg
https://cimg9.ibsrv.net/gimg/www.yot...22143d4fc3.jpg
https://cimg3.ibsrv.net/gimg/www.yot...2dcf747f30.jpg
https://cimg9.ibsrv.net/gimg/www.yot...41f17cb90d.jpg
https://cimg2.ibsrv.net/gimg/www.yot...5f7b2cd7dc.jpg
https://cimg3.ibsrv.net/gimg/www.yot...aefcb5721d.jpg
https://cimg9.ibsrv.net/gimg/www.yot...95f7feef2b.jpg
mad_sb Jun 2, 2016 07:03 AM
Price Updated, Will add some more details on the current condition this weekend. Runs and drives great, steering is like new, no wandering, slop, etc. Trans will need to be rebuilt soon but everything works (4wd, torque converter lockup, all gears etc).
I really don't want to put this on Craigs List and sell it to someone that won't appreciate the work I put in, so if someone from the forum is interested, make me a reasonable offer!
mad_sb Jul 2, 2016 06:47 AM
updated price
