Project "Wabbit" 1985 Toyota 4Runner
Purchased Oct 2004
Fall Crawl Sept/Oct 2006 at River Rock
SE4RJ3 May 2006 at Tellico ORV
1985 Toyota 4Runner
2.4L 22RE 4 Cylinder Motor
W56 5-Speed Transmission
Performance mods:
Professionally rebuilt 22RE
LC Engineering Header and High FLow Cat w/ custom exhaust
Suspension and Drivetrain:
All Pro 5" Extreme Lift
30 spline Longfields w/ chromoly hub gears
Front chromoly axles
ARP steering arm knuckle studs
ARP wheel hub studs front and rear
Knuckle gussets/shock mounts
FROR rear full floater adapter
Rear chromoly axles
Rear Aisin manual hubs
6 dowel pin mod on Aisin hubs and wheel hubs
ARB RD1 front and rear
Custom built front and rear drive shafts w/ CV joints
Differential breathers front and rear
Brakes:
All Pro t-case brake kit
Rear brakes: small IFS calipers w/ vented rotors extended brake lines
Front brakes: large IFS calipers w/ vented rotors extended brake lines
Summit manual proportioning valve - LSPV removed
1" bore LC master cylinder w/ new slave cylinder
Tires and Rims:
15x8 black rockcrawler steelies w/ 3.75" backspacing
GreatLake Off-Road custom beadlocks powder coated by Loudin's Powder Coating
39.5/13.50/15 Bias Ply Iroks
2" wheel spacers on the front
Protection:
4x Innovations DOM Kick Out Sliders
Trail Gear large diff armor front and rear w/ socket head drain plugs
Interior:
Gutted
Miscellaneous:
All custom powder coating done by Loudin's Powder Coating
Extreme Air 100% duty cycle OBA
Viar 2.5 gallon air tank
Custom wiring harness
Slee Off-Road air manifold
Grant custom removable/locking steering wheel
Cobra 75 CB radio w/ 4' Firestik
To come in the next year:
3-link rear suspension
Tubed front clip w/ exo cage w/ front bumper/stinger and winch rear tire fold up/down tire carrier
Full hydraulic steering
Electric fan w/ dccontroller
Dual Ultimate Crawler w/ twin stick d-shaft rework
Custom paint job or wrap for WabFab Off-Road
Fuel cell
Relocated rear shock mounts
Rock crawling seats w/ 5 point harnesses
ARB freezer for cargo area
Triple battery system reinstalled
Rework dash and move battery etc to in cab
And much much more I'm sure.
See all my progress documented on my build up thread on Yotatech or on my website on my "projects" page.
Build-up thread here on YT
https://www.yotatech.com/forums/showthread.php?t=43754
1985 Toyota 4Runner
Performance mods:
Rear chromoly axles
Brakes:
Tires and Rims:
Protection:
Interior:
Gutted
Miscellaneous:
Fuel cell
FS[MidWest]: 1995 4Runner 5vz 4x4
vasinvictor
Jan 20, 2016 12:39 PM
Eagle564
Jun 23, 2015 11:29 PM
JaredL
Jun 16, 2015 04:47 PM
