Engine Swaps Swapping an engine in your Toy, here is where to learn how
Mating 20r to 91 r150f from a 3vze 4runner
Old Sep 3, 2023 | 09:51 AM
Drift420's Avatar
Plan on doing a 3vze to 20r swap on my 91 4runner 4x4.
need more info on if my input shaft is the right size and what motor should i use the fly wheel and clutch from?
3.0 is giving out and not giving me any codes to check so im done with it. And i imagine a shop is going to make me pay way more then i would like to ever put into a 3.0.
I have stuff setup to get a 20r jasper motor + r151f bell housing + and my r150f trans.
3.0 will run fine when started up and for like 2-3 blocks but then starts sounding like less and less cylinders are running. Like starts at all 6 then 4 then 3 then it dies out. Happened out of the blue. The first month or so having the truck there were no engine issues. Now i can berraly get it to work and back.
Any help with either things will be appreciated.
Dont need any cons of the swap.
I just want a simple carbed motor instead of the messy 3.0 engine bay with 2x the vacuum lines then
any car should need..
Mike Wisham
Jun 17, 2021 03:23 PM
moroza
Feb 11, 2015 03:16 PM
pvault
Feb 3, 2014 04:33 PM
jaredandlindsay
Dec 30, 2008 08:28 PM
