Power Steering Box Rebuild - Still Leaks...at a loss
Old May 25, 2020 | 10:33 PM
yota_terror's Avatar
Hey everyone. I've rebuilt my 88 power steering box and the thing still leaks... from the threads where the lock nut secures the preload adjustment by the input shaft.
I have replaced the seals, o-ring and input shaft seal (1 and 2 in the diagram)..I even took it apart again tonight and replaced the o-ring and input shaft seal with another set. I have 3 steering box kits since I tore the damn teflon ring twice, lmao.
I made match marks and lined everything back up how they were before. I tried tightening the adjuster in more to maybe "seal" the o-ring, but it still leaks, and obviously gives it too much preload.
Any ideas? I know the lock nut isn't on in the picture, but I believe it shouldn't leak regardless. The locking nut doesn't have an o-ring or anything that would help it seal the threads. It leaks with the lock nut on too. Does this need thread sealant? Haven't seen much mentioned about this in any of the rebuild threads (such as the this link here) or videos on YT.
Old Feb 18, 2024 | 04:57 PM
pvannattan's Avatar
Did you find a fix? Battling this same thing right now..have changed exactly what you have with no luck. Really don't feel like pulling it out and doing a full rebuild if i don't have to!
Old Feb 19, 2024 | 07:54 AM
Jimkola's Avatar
YT Community Team
5 Year Member
I did wrap the splines and that lip on the worm gear where the seal rides with electrical tape as i was putting it into the housing with the seals. Came off easily once the worm gear was seated.
BlackPearl808
Apr 5, 2020 09:48 AM
gyates93
May 26, 2018 05:08 AM
lordhowe
Nov 24, 2010 08:38 PM
ToyYoda
May 9, 2010 11:13 AM
