Two bad alternators or bad wiring?
Old May 8, 2020 | 08:43 AM
Lawrence Bullock's Avatar
Wrecked my truck. Drive fine for weeks then the battery light came on. Parking Brake light doesn’t light up. An i changed the alternator twice and battery light is still on. Could i have a bad connection on my 80amp fuse? Or bad connection at alternator plug?
Fuse box damage
Alternator plug wiring
Old May 8, 2020 | 11:52 AM
2ToyGuy's Avatar
First, repair those alternator plug wires. At the very least, pull the pins out of the plug, put some heat shrink on the wires, and put the pins bak in. Best whould be to pull the pins, clip the wires at the far side of the break in the insulation, and crimp new pins on, then re-install them into the plug.
Second, I would pull the wire going to the fuse box off the positive battery terminal, and clean it thoroughly. It looks somewhat corroded, and even a small amount of corrosion can completely break a circuit.
Just my opinion, though...
Pat☺
Old May 12, 2020 | 06:35 PM
RAD4Runner's Avatar
Bad wiring.
Here.
https://www.yotatech.com/forums/f116.../#post52401963
RogueYota
Mar 22, 2011 05:27 AM
Blackulua
Mar 30, 2010 01:44 PM
fireman1102
Nov 23, 2009 06:04 PM
neq0323
May 16, 2009 04:54 AM
abourgeois
Jan 31, 2009 08:35 PM
