Tacoma ecu swap
Old Sep 16, 2019 | 09:39 AM
Seaman34's Avatar
Tacoma ecu swap
I have a 2002 Tacoma prerunner doublecab v6 that I swapped to a 4x4 manual trans with j shift. I have wired my truck to get it running but it cant get the CEL to go away. Would I be able to put a 4x4 m/t ecu from a different year tacoma and have it work? For example there is a 2001 ecu for sale near me.
Old Sep 17, 2019 | 10:06 PM
old87yota's Avatar
Welcome!
Do you know what the Check Engine Light is for? What Codes?
You will probably need an ECU for a manual 4WD Tacoma, since that is basically what you have now.
Hopefully someone who knows these Tacoma ECUs better than me can tell you what ECU you might need.
Old Sep 21, 2019 | 06:10 PM
fierohink's Avatar
As Oldboy said you’ll need an M/T 4wd ecu. What did you do with the plugs that went to the auto? How have you rigged a clutch safety switch?
Have you scanned the codes to see what the source is? It could be totally unrelated to power train and you have a bad coil pack.
Old Sep 21, 2019 | 08:35 PM
Seaman34's Avatar
For most of the plugs that went to the auto I wired in resistors so that I wouldnt get a code. I have not rigged a clutch saftey switch and do not know what wires in the harness I would need to use to make that work. I scanned the codes and got one for missing speed sensor and park neutral safety switch.
I have bought an ecu and it is being shipped to me now but I dont know what changesI need to make to the harness for things like reverse lights and speed sensor to work
mosk
3.4 Swaps
35
Nov 8, 2017 10:31 AM
AnthonyVB
3.4 Swaps
Aug 21, 2014 05:40 PM
toyotanick
3.4 Swaps
Sep 1, 2012 05:01 AM
modsquad
Aug 23, 2008 02:56 PM
mt_goat
13
Apr 27, 2005 06:21 AM
