1998 4 runner 4x4 only disengages when vehicle is turned off!
Old Apr 24, 2019 | 06:25 PM
jonnypage's Avatar
Hi there. Long time lurker first time poster.
I have an issues. I have a 1998 3rd gen 3.4 auto LTD
4wd engages just fine but when I disengage nothing happens even if I am in neutral or back up or forward. All the tricks.
IF I turn the vehicle off and then immediately back on the light goes off and I get back into 2wd
I have tested both VSV's for the 4wd. Both resistance and making sure they are getting power to when switched.
I have checked the front diff sensor and that checks out.
What am I missing here?
Picture for Reference of the vehicle driving me mad
Old Apr 25, 2019 | 09:24 AM
Jomoka's Avatar
Perhaps one of the VSV is testing OPK electrically, but is physically stuck open? And that's keeping it stuck in 4WD.
Symptoms don't seem quite 100% right for that scenario, though.
Old Apr 25, 2019 | 09:41 AM
jonnypage's Avatar
I am leaning towards an issue with those but I sucked on them and they seem to hold pressure. I just can’t think why cycling the ignition off and on would change anything. Maybe the one way vacuum valve?
Old Apr 27, 2019 | 07:32 PM
fierohink's Avatar
One of the position sensors on the transfer case is causing the error.
Old Apr 27, 2019 | 09:09 PM
jonnypage's Avatar
What makes you say that ?
Old Apr 28, 2019 | 11:41 AM
fierohink's Avatar
While most people get freaked out by the complexity of the m/m 4wd and transfer case, there really isn’t a whole lot to them. There is an actuator in the transfer case and in the front diff, and then a bunch of position switches to tell the computer where everything is. VSVs don’t often go bad because they are always under vacuum, they sometimes “show” being bad because a position switch is telling the computer to do something opposite of what you are trying to accomplish. Meanwhile the position switches rarely get used and moved since most people seldom shift into and out of 4wd.
Old Apr 28, 2019 | 12:03 PM
jonnypage's Avatar
Reply.
Awesome I’ll pull those and test them. Are they just open closed switches ?
Old Apr 28, 2019 | 12:59 PM
fierohink's Avatar
Yup. That’s it.
Old Apr 28, 2019 | 01:25 PM
jonnypage's Avatar
Is there two? Or 3? Parts diagram looks like 3
Yup. That’s it.
Old Apr 30, 2019 | 02:18 PM
fierohink's Avatar
There are possibly 4. Hi/lo/neutral/4wd. 2 are down low off the actuator and 2 are up high near the floorpan.
Old May 12, 2019 | 01:49 PM
jonnypage's Avatar
Update
Well i tested two switches up high on the transfer case one with a dark coloured connector and one with a grey. They are both fine.
I tested the switch on the back near the actuator. and that tests fine too. Is there any way to test the actuator?
Old May 12, 2019 | 01:56 PM
jonnypage's Avatar
update 2.0
I have also noted that when the truck is in 2wd you cannot spin the front drive shaft by hand
Old May 12, 2019 | 06:04 PM
jonnypage's Avatar
I seem to have fixed it. I pulled the transfer case motor out. And as I did the selector shaft pushed the motor out also. It seems that it has been off before and not reinstalled correctly. For reinstalling I removed the triangular cover with 8mm bolt heads. Manually engaged 4wd by pushing the selector shaft all the way in. then with the gear out of the triangular port and the motor connected to the wiring harness I engaged 4x4 with the button. Then installed the actuator onto the back of the t-case. Then inserted the gear and re fitted the triangular plate. All tight and reinstalled seems to now engage and disengage fine now
searay42
May 17, 2016 12:45 PM
neilo
Mar 22, 2013 04:45 PM
pendrag
Jul 12, 2010 07:06 AM
XPY
7
Oct 18, 2006 08:56 AM
