Engine Swaps Swapping an engine in your Toy, here is where to learn how
1992 3.0 v6 to a 3.4 from a 1998
Old Nov 17, 2014 | 08:56 AM
charles4376's Avatar
what do i need to complete the swap? i got the hole doner car its auto mine is manual
Old Nov 17, 2014 | 10:02 AM
JasonYota's Avatar
You bought a entire donor so you already have everything you need.
Old Nov 17, 2014 | 11:37 AM
Alex904r's Avatar
Hello, all,
I continue to struggle with my 89 4R, which runs and shuts off.
Got offered a 3.4 to replace original 3.0, somethin I would eventually do but opportunity knocks.
Question. Donor is a 2002 4R, with the 3.4.
Mine, of course, is the 3.0, 5 speed. Although I have read as much as I can find about the swap here and else where, does anyone know if this is a doable swap? Will it bolt to my tranny? ANy major problems about I should know?
Thanks for all your input
Alex
Old Nov 17, 2014 | 12:18 PM
JasonYota's Avatar
Originally Posted by Alex904r
Hello, all, I continue to struggle with my 89 4R, which runs and shuts off. Got offered a 3.4 to replace original 3.0, somethin I would eventually do but opportunity knocks. Question. Donor is a 2002 4R, with the 3.4. Mine, of course, is the 3.0, 5 speed. Although I have read as much as I can find about the swap here and else where, does anyone know if this is a doable swap? Will it bolt to my tranny? ANy major problems about I should know? Thanks for all your input Alex
You have read as much as you could find and didn't find if it will bolt up to your existing trans? Have you looked in the 3.4 swap section??
Old Nov 17, 2014 | 12:49 PM
wyoming9's Avatar
Red face
For you most likely not!! It all depends on your mechanical aptitude and your research capability .
Your not off to a very good start
There is a bunch of info pretty much answer all your questions .
Old Nov 17, 2014 | 01:11 PM
so what do I need to by to complete my swap that I don't already have from the donor car? I need help getting the correct information going in to this
Old Nov 17, 2014 | 01:35 PM
Alex904r's Avatar
3.0 to 3.4 swap
THanks for the replies.
Yes. I did read the section on 3.4 swap, including this you included. I guess formulating the question better would have been a plus.
I know that 3.0, 95-2004 are comparable, but what I don't know is if all 3.4 are "created equal" or there are limitations when attempting to swap. The articles I have read do not make a specific reference and most swaps do not include anything in the 2000's...at least, I have yet to see one. Of course, I am new to this forum so forgive my ignorance. Thanks
Old Nov 17, 2014 | 08:09 PM
vital22re's Avatar
totally a bro
sometime in the 2000's they stopped drilling the block for a dipstick. That and electronics will be the biggest difference. As long as you get a complete donor with all matching components you're set. Most people take the opportunity to freshen up the donor motor while its out.
Old Nov 17, 2014 | 10:58 PM
Alex904r's Avatar
3.0 to 3.4 swap
That's great. THANKS.
https://www.yotatech.com/forums/imag...ies/bounce.gif
93toyoguy
3.4 Swaps
10
Sep 18, 2015 04:16 PM
sphealy
Sep 3, 2015 07:55 PM
dlaiben
3.4 Swaps
Sep 3, 2015 09:57 AM
93toyoguy
Aug 2, 2015 07:41 PM
