Engine Swaps Swapping an engine in your Toy, here is where to learn how
2.8 i6 to 86 hilux?
Old May 24, 2014 | 03:15 PM
busabiker129's Avatar
2.8 i6 to 86 hilux?
Has anyone ever swapped a Cressida motor to a 86 toyota hilux? I have a 1986 hilux with a blown motor. I found the cressida at a fair price and was curious if anyone had done or attempted the swap? If so were there any problems with fit or bolting up? TIA
Old May 25, 2014 | 06:50 AM
superextracab's Avatar
I did a 7m in my 85. I didn't have much trouble. I think the 5m would be a little easier because the crank pulley isn't quite as long and the 5m hard mounts should make it so the frame mounts are in the correct position. Just research any clearance issues you may have clearing the diff with the sump.
Old May 29, 2014 | 09:18 AM
Hadmatt54's Avatar
I put a 5m-ge in my 86 pickup a few years back, it worked really good. My truck was a 22re so, using the stock crossmember in the stock location, I used the 5 m motor mounts, but I had to fab new frame brackets and massage the rad support to get the 5m rad recessed so it would clear the mechanical fan. If you want to make the swap easier find an 84-85 supra 5m manual and get the ECU, the engine harness, bell housing (bolts right up to a W56), flywheel & bolts (generally flex plate bolts are not as long), clutch and the fuel pump and bracket. Where your truck is a 22r I'd also try and find an 86 that was a 22re and get the fuel tank and harnesses, as your tank is not made for an internal fuel pump or return lines, and your wiring harnesses are probably missing a lot of what you need for fuel injection. You will have to build fuel lines (return), the clutch cylinder is on the opposite side from your truck and so is the exhaust.
Old May 29, 2014 | 09:57 AM
blake.nemitz's Avatar
I swapped a 2jz in an 86 4runner and it fit with a little massaging
Old May 29, 2014 | 09:59 AM
there are 2 electric puller fans behind radiator but it is tight Name:  20140404_213919_zps6abbdee4.jpg
1993hiluxsr5
Dec 4, 2024 07:02 AM
RSR
Diesel Swaps
14
Oct 26, 2013 10:19 AM
hjalti_gto
Engine Swaps
22
Nov 27, 2011 09:14 PM
1993hiluxsr5
Dec 20, 2010 04:16 PM
1993hiluxsr5
Oct 3, 2010 03:34 AM
