'91 Toyota unlocked hubs are turning
Old Dec 31, 2013 | 01:25 PM
GSBoone's Avatar
Question '91 Toyota unlocked hubs are turning
1991 Toyota 4x4 with manual hubs, one axle spins forward, the other in reverse in 2WD, unlocked. Truck has 1 1/2" ball joint spacers and diff drop kit. What is wrong?
Old Dec 31, 2013 | 05:03 PM
90YotaPU's Avatar
It sounds like you have it jacked up are turning them by hand and it's acting like a typical differential is designed to.
Old Dec 31, 2013 | 06:55 PM
houston's Avatar
diff shouldn't turn if the hubs are unlocked, could be something busted inside the hub, might be a good idea to pull them apart and inspect the mechanism/gears
Old Dec 31, 2013 | 07:50 PM
GSBoone's Avatar
Thanks, I would of sworn I thought it was not a hub problem, but after pulling out right side hub, noticed bad internals and that shaft could not disengage. No problem to repair/replace.
Himashi
Oct 1, 2015 07:29 PM
Bamripzit
Jul 19, 2015 01:17 PM
Bamripzit
Jul 13, 2015 07:21 PM
bowhunter1640
18
Jul 5, 2015 03:30 PM
Bamripzit
Jun 20, 2015 04:53 AM
