22RE wont rev past 1000rpms after rebuild
done with rebuild and engine started right up, got oil pressure, but wont rev past 1000 rpms...any ideas? tried running disconnecting AFM and TPS separately but didnt make any better...tps may have got a lil wet when degreasing bay...does this ruin it or can it be somehow dryed/fixed? Thanks in advance! - Jon
yeah its gotta be the tps :/ no multimeter...guess ill try cleaning it off with some wd40 and see if it works...if not guess Ill try and snag one down at the pick a part manana...anyone know what years/cars are compatible for 88 22re
i never disconnected the AFM just unhooked all the intake ducting and know I didnt get it wet...Im sure I got the TPS soaked when degreasing :/...im gonna grab a multimeter and test the tps... if its broken from water how will it test? dead or just have dead spots? Thanks
-Jon
-Jon
3 seconds on Google turned up this.
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
^My94yota...hey I just got back from vacation this week so am getting back goin on her...All Ive done this week is just re tinted my rear windows from 35% (too light!) to 5%. Picked up an ohms meter at Harbor freight and am going to test the tps today...Will keep yall posted...thanks!
well i cant get it set in the range 200-800 ohms on the VTA-E2 closed position test via instructions on 4crawlers site. I keep getting like 1.7-2 reading (20k setting)..Im assuming this means my tps is no good?
http://4crawler.com/4x4/CheapTricks/...roubleshooting
Well I threw another Tps on it, adjusted it to spec and re did timing. It was running decent. After nearly passing out from exhaust fumes during the cam break in (shoulda opened garage door, lol jk) I came to notice oil leak pissing all over engine bay.
Any ideas where I should start looking...it's somewhere leaking onto the belts and spraying all over. Oil pump?...?
Thanks
Thanks
well I replaced the front main seal a few months ago, seems to have fixed the leak *crosses fingers*....After 4 months of not touching the truck the school semester ended yesterday so that means today I was working on her, lol... Got the timing set and couldnt figure why it was running so rough til I noticed idle at like 450...bumped up to around 700 and it took care of the violent engine shaking....Now I guess Ill put some gas in it that isnt over a year old and drive it for a bit then try and PASS CA SMOG
which I doubt it will... And I guess I could wash and wax it since I have never done either in the over a year Ive had it...more updates to come!
shadowbirdie
Jul 21, 2015 10:38 PM
