94 4runner 3.0 timing isue
Old Dec 24, 2013 | 03:09 PM
jimmyjoebillybob's Avatar
Hey, Ive got a 94 runner 3.0 auto. Bout a month ago I replaced the t-belt and water pump. We went out of town for the holidays and it ran like crap. When we got here I put the jump wire in and tried to time it. With the jump wire in, it was at like 15 deg after tdc and the closest I could get to 10 before made it run worse and spark knocked bad. Any ideas where I should start looking? Did the t-belt jump? Any help would be awesome thank you.
Old Dec 24, 2013 | 03:20 PM
Bigblock's Avatar
They installed the t belt 1 tooth out of time. Easy fix.
Old Dec 24, 2013 | 03:33 PM
scope103's Avatar
No, no. I think you mean the distributor was re-installed 1 tooth out of time. (the distributor gear has 13 teeth; miss by one and you're off about 28°. Does 28 sound familiar?)
This mistake is easy to make, and easy to fix. http://personal.utulsa.edu/~nathan-b...13distribu.pdf
Old Dec 24, 2013 | 06:58 PM
I did the work myself and it was running great for like 3 weeks. then the coolant temp sen went out then i changed the plugs and it ran even beter but now it misses at idle and when i come to a stop it wants to die and my mpg has gone down the drain
Old Dec 24, 2013 | 07:01 PM
And when i put the jeep wire it doesn't seem to change the timing mark. like its not turning the advance off
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
Alaskan91
Sep 21, 2015 04:39 AM
ZONAYODA
Jun 30, 2015 05:36 PM
yamaha73
Jun 18, 2015 06:19 PM
HALMAN
Jun 14, 2002 09:02 PM
