1990 2wd rear sag -FJ80 coil?
Old Dec 22, 2013 | 07:44 PM
Natosports's Avatar
1990 pickup 2wd rear sag -FJ80 coil?
Hello,
I've read a lot about the issue with the 2nd gen rear sags. But most of these post are about 4runners. Well, my 1990 2wd pickup sags too. And I don't have the tools to fabricate a Zuk mod. I just want to have something easy to help lift this rear back to match the front. A friend of mine is giving me his front a rear FJ80 coils. Can I just pop this in to the rear and call it a day?
Old Dec 22, 2013 | 10:45 PM
DeathCougar's Avatar
If you can't do the Zuk mod, how do you plan on putting the FJ80 springs in?
ZUK=Coil springs
FJ80= Coil springs
Am I missing something here?
Also the FJ80 springs are WAY too tall/heavy duty for a 2WD truck.
Old Dec 23, 2013 | 05:49 PM
Natosports's Avatar
Thanks for answering my post. I was thinking to have my mechanic install the springs. Well, I took a look at the bottom of my truck today and I notice that the leafs are positioned on the bottom of the axle, held together by a U-bolt. The way the 2nd gen pickups are very different from the 4runners. The bump stops are on the top instead of on the bottom as compared to them 4runners. I searched and searched on this forum and I see a lot of people doing the zuk mods, cut and non-cut. But I haven't been able to find a post for the 1990 2wd pickup. Sorry to ramble on over here cuz I'm new to this.
Old Dec 23, 2013 | 07:04 PM
Robert m's Avatar
Just do it the right way and replace the leaf packs or do an add a leaf. As you found, the 2wd rear suspension is not setup the same as the 4x4 stuff so you would have to weld on a coil spring perch for the coils to sit on the axle.
smthwsn357
May 1, 2024 07:28 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
Nickdigg
Jul 7, 2015 06:04 AM
ptb12
Jul 5, 2015 01:49 PM
Vargntucson
Jul 4, 2015 12:15 PM
