Cylinder head-re installation, chasing head bolt holes
Hi everyone. I'm in the process of installing a new head on my 22re and can't find a tap to clean out the head bolt holes into my block. Its a M12x1.25 tap that's needed. All I can find is 12x1.5 and 12x1.75. At my local parts store they don't even have one in the catalogue. Since I cant find one anywhere my only option seems to be to clean up one of the old bolts and use it to clean the holes out as best I can, which feels like a very mickey mouse way of doing things to me. Anyone have any insight or ideas??
The M12x1.25 is a fairly common tap.
Your local parts guys need to dig a little deeper, if one tool company does'nt have the tap, another one will.
You can get one shipped from China for $7.80US on Ebay.
http://www.ebay.com/itm/New-12mm-1-25-Metric-HSS-Right-Hand-Tap-M12x1-25-Pitch-/170917947756?pt=LH_DefaultDomain_0&hash=item27cb80e96c
If you ordered a new set of head bolts, use an old one. I had the same problem. My tap set didn't have the right TPI. I purchased new head bolts and took an old one then cut a slot perpendicular to the threads with a cutoff wheel. The reason for the cut is to allow the debris a place to collect. It worked like a charm!!!
You really should get a new set of head bolts.
Also, try http://www.mcmaster.com/#
Chase the threads. I bought my thread chaser set from Sears. It was in the neighborhood of $30 or $40.
if you can afford it, use new head bolts, at the very least, inspect each bolt for wear, stretching etc . And use a thread chaser only. You live in Canada, Canadian Tire has them for loan, leave a deposit, use it, bring it back and get deposit back.
I bought new head bolts and cut the end off one of my old bolts to clean it up. I didnt have the time to wait for a chaser because of the gong show that is the week before christmas and needing my truck put back together quick. Thanks for the tips.
I just re-torqued my head bolts after a few hundred kms and they were surprisingly loose. My haynes manual and the manufacturers recommended specs are both 58ft-lbs which seems pretty low. Anybody go above that?
Sep 4, 2015 09:27 AM
