Help! Brake options for 2wd Yota- New Arm is interfering with caliper.
Old Dec 15, 2013 | 09:36 PM
87xjmike's Avatar
I'm not quite sure what to do about this, i need a slimmer brake caliper... Anybody know of some viable options?
This kit was ran before so it had to of worked for some one.
Old Dec 15, 2013 | 11:27 PM
JonnyBoy's Avatar
Let's start with what brakes are on there now. They look like they're 2 piston by the angle of your pics, so the stock 2wd calipers?
Old Dec 16, 2013 | 07:22 AM
87xjmike's Avatar
Stock 2wd single piston calipers on a modified 2wd spindle but the caliper ears are in favtory location. I might have to cut the ears amd mount them further up. Or make a bracket to extend caliper out. Somebody ran this kit before so I know domethimg had to of worked. Just not sure what.
Old Dec 16, 2013 | 09:25 AM
Robert m's Avatar
dont know if it will work or not but maybe try doing the 4x4 brake swap like this http://www.toyotaminis.com/forum/sus...onversion-252/
only problem i see with it might be wheel to caliper clearance if you are running a 15'' wheel.
edit: saw your update on DR. do the stock brakes fit now?
Old Dec 17, 2013 | 10:32 PM
87xjmike's Avatar
No, i still need to redo the whole brakes. I'm going to build a bracket to extend them out, use a 12" rotor and find a caliper to work. Which rotor and caliper is the question. My hubs are 3.5" Wide id so i'll likely have to turn out any rotor hub i find. the backspacing is what concerns me.
okamikai
Apr 30, 2018 10:19 PM
Yota.Jay
28
Oct 22, 2015 01:08 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
kirkrunner
Jul 27, 2015 07:59 PM
msane99
Jul 17, 2015 10:13 AM
